smaller turbo and smarty ASAP
just got back from my first dyno run ever with this truck and boy do i need to make some changes. my numbers arent shabby but could be SO much better with a smaller turbo and a smarty. this modified hx-55 is JUNK IMO...but thats another discussion
now for the numbers
1st run-no comp box
356.24hp/683.20tq...not too bad for no box
2nd run- comp box on 5x5
429.83hp/789.54tq
3rd run- same as second run
430.29hp/789.59tq
pretty consistent for the 2nd and 3rd runs, but i think with a few minor changes i can get it closer to 500/900 range
i should be higher, but the tires absorb a little HP and the lag of that turbo is killing me, with a comp box on the highest level im only gaining 60hp and 100tq at the wheels. now i also understand that the dyno operator was running all the 6spd trucks in 6th gear rather than 5th gear (1:1 direct drive) so that may be part of it. overall it was an awesome day with about 60 or so trucks and 30-some hitting the dyno.
now for the numbers
1st run-no comp box
429.83hp/789.54tq
430.29hp/789.59tq
i dont wanna give away the info but a another member here made some impressive runs with his particular set-up which REALLY suprised me...and he was all smiles to prove he could beat me.
im sure we will see his post later this evening
a little smoke at first then cleared up...with the comp on i blacked out the parking lot until about 2200rpms then it started to clear
as soon as i sell these 2 turbos ill have the cash for a phat shaft 64 and smarty
Originally Posted by BigBlue
First off I'm pressed with your no comp dyno run. With my 100hp injectors I only did 230hp with no comp. But I went up to 398hp with the comp on 5x5. A smarty and a smaller turbo should really help you.
230hp with 100hp injectors? What's up with that?
