Slotted rotors?-Brake pads-Ceramic vs. Carbon vs. semi-met?
fishbait:
find you a PepBoys and ask them for the lime green pads they sell, can't remember what they were called. i believe they're mostly kevlar, been a good pad for me , will definately stop all six wheels, don't know how hard they are but they're holding up good and it's been a year. !!!
Originally Posted by Fishbait
Please tell me more of this cylinder upgrade....before my wife spends all my next check!!!!!!!!!!!
The mod is described in more detail here-
https://www.dieseltruckresource.com/...threadid=43854
Switching from a 27mm (stock Ram 3500) to a 30mm cylinder increases applied force area from 572.55mm^2 to 706.85mm^2.
That's over a 23% increase, on a pre '97 2500 the increase is over 50%.
This mod works on all drum brake Rams.
What are the thoughts on pads? Could not find any Ceramics local for Besse, but I have (since i was a kid) heard that premium semi met pads were harder on your rotors than the 20.00 cheap pads
The more pricey pads usually squeak and wear out your rotors.
Ceramics are great for little cars but are notorious for ruining the rotors on our trucks.
1 Post
TireRack website states "no Hawk brakes for my truck" This can't be correct...
Originally Posted by Diesel_Dan
What are these Wheel Cyl upgrade that is mentioned...this is the first i have heard of this...and would LOVE to do it for $30! Is this something had at NAPA or some web site? Thanks!
Dan
Dan
It's really simple to do. And it helps a lot. It's cheap to.
I ran the cheapest pads on my truck once and I'll never do it again. They destroyed my rotors. I mean DESTROYED my rotors. They look like the freaking ocean they are so grooved and wavy. So now I'm running the really expensive ones. Those haven't ground my rotors down nor have they ground my roommates rotors down.
"el cheapo" pads ussually contain a higher concentrate of metallic material in them, in turn creating more heat, which isn't good for any rotor. Plus the squealing and the dust are enough to drive you bonkers. I've had great luck with Bendix FleetLok Metallics, have them on 3 trucks now, and had them on a Caprice I used to have. Never had them eat up a rotor and they deal with heavy braking very well. Granted, they aren't available for all vehicles but I don't know why they wouldn't be for any of our trucks.
Dynocon
02-04-2015 08:40 AM
MR HYDROSEED
07-30-2007 09:54 AM
Mcmopar
05-11-2004 09:46 PM
MoreSmoke
02-10-2004 11:28 AM
