Slip yoke conversion
Old 12-19-2004 | 01:24 PM
perk's Avatar
Is there a kit out there to convert from a slip yoke on the back of the 241 HD to a fixed yoke? It is time to replace my rear output yoke so now would be the best time to do it.
Old 12-19-2004 | 06:01 PM
apache's Avatar
Might wanna call Tom Woods driveshafts on that one. I belive he`s in utah somewhere. He seems to be one of the premier drivelines guys. I know its common on the cherokees with the smaller TC. I would imagine it could be done.
Old 12-19-2004 | 08:23 PM
mkubacak's Avatar
http://www.jbconversions.com/pages/
Old 12-20-2004 | 12:02 PM
royta's Avatar
For my Cherokee, I used the Advance Adapters SYE (Slip Yoke Eliminator), and had Tom Woods build me the driveshaft. Tom Woods is a top notch guy.
Old 12-20-2004 | 12:32 PM
CTD NUT's Avatar
Advance adaptors, Tom Woods and JB will all be able to provide you with the correct slip-yoke eliminator kit.
Old 08-24-2009 | 09:31 PM
Plumb Wild's Avatar
Thought I was the only one with this problem...makes everything under the bed a mess!!! Would all I have to order is the SYE kit off the site and thats it? No modification the the driveshaft of u-joints etc.?
Old 08-24-2009 | 10:35 PM
royta's Avatar
The driveshaft would need to be physically longer, plus you would need a double cardan joint on the driveshaft instead of the single u-joint.
Old 08-25-2009 | 05:53 PM
Tate's Avatar
Your driveshaft would have to be a two piece, since it now has to change length as the suspension cycles.
Old 08-25-2009 | 08:22 PM
Plumb Wild's Avatar
I imagine all in all this would be a stronger setup right? As far as driveshaft strength goes?
dieselcarpenter
09-18-2007 07:01 PM
sajigore
02-20-2007 03:54 PM
Smooshy
08-14-2006 10:15 PM
TE-44
08-08-2006 12:44 PM
Holsteinman
04-08-2005 04:15 PM
