Sled Pullin
Old 05-23-2008, 09:14 PM
pickupman96's Avatar
Sled Pullin
Well there is gonna be a pull in my area for the first time in a few weeks and im gonna hook for the first time. What other mods should i do before I hook, advice, anything to help me out because I really dont want to look like an ****. Thanks for the help.
Old 05-23-2008, 09:33 PM
ct2500's Avatar
were about in C.T. is there a pull this time of the year?
Old 05-23-2008, 10:17 PM
J Lent's Avatar
Take your floor mats out & hold the go pedal to the carpet. I'm a manual guy, can't help with the auto launch. How much boost ya running?
Old 05-24-2008, 09:37 AM
adidasman23's Avatar
if you can try to block the rear end so it don't sag your rear end. Give her hell and don't stop until you see red(flag) and good luck
Old 05-24-2008, 09:18 PM
The pull is in Goshen June 13-14. Its making 47psi. I was going to block the rear but the rules say that I cant
Old 05-24-2008, 10:12 PM
Do they say you can't or have to have an 1in of travel. Lot of these places I go to say you can't but I do anyways. The cheapest way I found to do it
is use some 4 to 5in c channel and put it on top of your leaf springs and the bottom of your frame. You might have to jack your truck suspension to put it under.
Old 05-25-2008, 06:43 AM
olddodgetruck's Avatar
is it a run what you got pull, or do they have classes.
Old 05-25-2008, 09:31 AM
They have it broke into 5 classes. 4and 6cyl trucks, midsize gas v6 or 8 like dakota's t-100's, fullsize gas, fullsize diesel, and then bigtrucks and duallys are together. Check out the site www.goshenstamede.com
Old 05-25-2008, 05:35 PM
One other thing. I was out messing around today and broke the front driveshaft u-joint. In the process it broke the cv part on the front driveshaft, right around the snap ring that holds in the u joint. Where can I get a new one
Old 05-25-2008, 08:25 PM
LITTLE_BIG_ME's Avatar
For a manual with a basic stock pushing 33PSI of boost what gear should i start in with it in 4wd high or low? Never hooked up before any advice would help? The only thing i have ever pulled is the horses and cows in a trailer.
Old 05-25-2008, 08:33 PM
J Lent's Avatar
I hope that you have a dual disc, singles won't hold. If you have a DD, go 2nd HI & hold it to the carpet. If a single disc, go 3rd low & don't try to build boost before launch, just rev it & dump the clutch when it starts moving.
Old 05-25-2008, 08:49 PM
Thanks i have a single disk, kevlar and cermaic it dont slip but it dont like heat either, i really dont have anywhere to pull right here in southeast georiga. I cannot wait until i am back in missouri and build the pulling truck with my buddys. Looking a a first gen all mechanical with belt driven fuel pump.
Old 05-26-2008, 08:53 AM
ct2500's Avatar
wut about 4th 4low thats wut i was thinking about
Old 05-26-2008, 08:58 AM
J Lent's Avatar
You have a DD, you will be fine. You will have to ride the clutch out the hole & only use 4th LOW on a loose or muddy track. You will break something on a tight track running 4th low.
Old 05-26-2008, 01:29 PM
MCummings's Avatar
I got mine at NAPA.
Merrick
Quick Reply: Sled Pullin
