Skyjacker Saftey Issue
Very concerned. I was thinking my ball joints were going out due to the "death wobble"....after checking last night the skyjacker track bar drop bracket has cracked almost in half. Anyone else have this issue, recommend a fix (other than bracket replacement) or other replacement options? Many thanks.
The lift was installed about a year after new. Regardless, I understand some items on a lift system are "wear" items but a solid steel bracket? SJ wants me to buy another bracket @ $180+shipping and then return the cracked one to them for review/analysis. If "determined" by them the product is faulty then I'm guessing they'll provide a refund. Either way if a steel bracket cracks or brakes under "normal" wear it is a big saftey liability issue it should be more of a recall. After calling around yesterday to try and find a replacement locally, one shop stated they've seen their broken products come thru their shop more and more. The worse side is my truck is down for probably a week until it arrives via UPS and with the holidays who knows when that will be.
My buddy got add a leafs from skyjacker and one broke in half and half came out.... he has a 1500 and doesn't tow or anything doesn't really even offroad he called skyjacker and they said the same thing send it back a buy a new one... sounds like a bunch of a$$holes behind the counter
Drove almost like a cadilac before. I noticed recently the "wobble" and thought ball joints. After checking the bjs and everything else I then noticed the crack.
re
A month ago my skyjacker pitman arm broke in half. I called sky jacker and they where jerks about it. They said send it in and they will have it analized. I drive the interstate to take my daughter to day care as I was turning into the parking space could not steer any more, Pitman arm broke in two. I DID NOT PUT A SKY JACKER ONE BACK ON!
wont be using them after reading this!! you should forward the comments to skyjacker so they can see what customer service brings them.
Thanks for all the input...keep it coming if you have both "good/not so good" comments as I'll make sure they're aware of it when I apply for my reimbursement.
1 Post
I'm 100% on your side!!! Chinsey product, but you get what you pay for. I think the more expensive models use thicker steel. The only thing they have going is their price. Since people with big trucks are inherently cheap about buying parts. Mainly because they break from off-roading, or can't afford the lift and truck payment they opt for the cheaper skyjacker kits. This is of course no excuse to make an inferior product. I bought one for my ramcharger and just looking at the thin AWG steel they used, i swallowed the shipping costs and returned it. (after duplicating my own out of .25 and .500 of course) They definitely cheap out on the more popular 1/2 ton products.
1 Post
And here I always thought they made quality products... Guess i'll be looking elsewhere when I decide to jack the truck up after hearing these stories. Our front ends give us enough problems, no need to make it worse
I did some poking around yesterday afternoon and found anyone can submit "saftey" issuses to NHTSA.dot.gov and will probably file something when it's all said and done. Yes, true it will probaby take an accident or a severe incident to raise concerns at SJ but the claim will at least open an investigation.
