Skyjacker D25 install tips
Old 02-28-2003 | 09:23 AM
MARKY MARK's Avatar
I will be installing Skyjacker D25 2-1/2" coil springs today. Anybody have any tips to make the install go smooth?
Old 02-28-2003 | 10:40 AM
GO 4LO's Avatar
Re:Skyjacker D25 install tips
I have no idea if you need coil compressors or not, but if you do, Autozone rents 'em out for free. Just an FYI.<br>Chris
Old 02-28-2003 | 11:23 AM
GO 4LO's Avatar
Gear Poet, I saw the pics of your truck in the Photos section. It looks great!! How much lift do you have on there? What brand? What size tires?<br>Chris
Old 02-28-2003 | 11:45 AM
Jetpilot's Avatar
I did mine myself in about an hour. I did not use any special tools, but I did use the jack from inside the truck. I did one side at a time. Jacked the truck up and supported the frame with a jackstand. Removed the front wheel and shock assembly. Then I used the jack to spread the control arm to get enough clearance. Then just bolted it all back together and went through the same process on the other side.<br><br>Doug
Old 03-02-2003 | 10:12 AM
MARKY MARK's Avatar
Update:<br><br>A buddy &amp; I installed the D25's &amp; Bilstein 5100's Friday night. I am extremely happy. ;D Truck sits perfectly level &amp; the ride is so much better. Those red D25's look awsome with the silver &amp; black bilsteins. ;D ;D ;D
Russell
02-02-2004 03:30 PM
MARKY MARK
13
06-27-2003 06:50 PM
dingo
03-22-2003 02:38 AM
MARKY MARK
03-16-2003 11:32 PM
