Single vs Twin Disc Clutch
I am having a hard time making up my mind on this. I have never drove a truck with a twin disc in it and i need some more imput. I am looking for smooth engagement for backing to trailers and pulling in to my snowplow mount. I need to be able to creep in an inch at a time. How much slower are they to shift, i will be snowplowing with this truck and need to be able to hit reverse fairly quickley. How are they on the street for the once in a while need to speed shift. I will be working my way up to the 450-500 hp range down the road and would still like some work truck manners.
Dave
Dave
i have the south bend 3850 12 ceramic button sprung hub in my 07 and i like it better than any of the con ofe i had in previous trucks and you can back them pretty easy
GO South Bend DD 3250 for towing and mild playing and drive ability 3600 for moderate to frequent performance play and 3850 if you are going to be at the track all the time breaking stuff I have the 3250 and pull a trailer with it most of the time and it is every bit as good as the stock as far as shifting, although starting out can be a little grabby with the Smarty on but I love it and would recommend the DD any day! Better bang for the buck and remember you get what you pay for!!
I am thinking about giving Valair a try, i talked to Kevin there for about 40 minutes last week,they seem like decent guys that stand behind there product. In all the posts i searched in the forum i did not find a bad word about there products or service. They have a dual disc coming soon and it has a better price tag then a SB. I have nothing against SB but this stuff adds up fast. Thanks for the replys Dave
Thanks for the offer fox man i may have to take you up on it, i know the area and get there time to time, i drive straight truck out of Monticello. My main concern is shifting from 1st or 2nd to reverse. While plowing its nice to get off the pile fast. Do you have to wait for it to stop spinning, or is it not to bad, like an extra second or 2.
Usually I have to shift into 5 then bring it straight back into R, when im sittin still though! when your movin some though you can hit R.
Buy one and try it
Brandon
Buy one and try it
Brandon
I plowed with a dual disk for about 5 years and never had a problem, the speed shifting is more of a problem when at the higher rpms. There is NO better work truck clutch than a dual disk
Farmall Power
10-03-2009 07:33 PM
ShawnQ
01-12-2006 08:09 PM
