Simple mods & access. that you recommend
Old 10-16-2005 | 02:15 PM
Tommy93w350's Avatar
Smile Simple mods & access. that you recommend
Hey guys I love to read your mods and accessories about your trucks. Sometimes the little mods are the best mods. It makes our life easier, saves money and customizes our trucks for satisfaction.
Please reply with a few mods or accessories that you have enjoyed and want to share.
--I like the headlight mod by attaching the two wires together under the steering column.
--Storage under the rear seat.
--12V plug mounted in the rear of the bed for accessories ( air compressor).
--BHAF
--DSS
--4" turbo back exhaust
--Westin side bars ---Highly Reccommend!!!!
--Adjustable tri ball trailer hitch (Northern Tool)
Wish List
--Edge EZ or Van A. ?????
--Tranny upgrade
Share yours with us!!!!!
Old 10-16-2005 | 06:04 PM
dieseldork's Avatar
I MUST OF MISSED THIS ONE WHAT IS IT?
{--I like the headlight mod by attaching the two wires together under the steering column.}
Old 10-16-2005 | 06:17 PM
Both filaments lit when on high beam FYI
Possibly a new solution to an old problem.<br><br>I wanted to have my low beam lights to stay on when switching to high beams. I was poised with pen in hand getting ready to write a check for a Brite Box. Then I remembered that I was an electrical engineer and should be able to do this myself. I located the schematic for the lighting circuit in the manual and found out how it works. A simple procedure will eliminate the need for the Brite Box. There are those who will say that the light switch can't handle the current of both filaments being on at the same time. I have a 2002 so my switch maybe different than earlier years. I did, however, perform this modification to a friend's 2001 without any problems at all. To do the mod, remove the panel below the steering column. This will expose a bundle of wires coming from the multifunction switch as well as the horn, cruise control, etc. The wires of interest on my 2002 as well as my friend's 2001 are light green and violet with a white stripe. There are two light green wires. Make sure of the one you need before doing the mod. I used a piercing circuit tester light and found the correct light green wire by grounding the tester and piercing each light green wire and watching which wire caused the tester light to go on and off when the light switch was turned on and off. Having located the correct wires, I used a wire tap connector to short these two wires together. The wire tap is designed to allow you to connect a new wire to an existing circuit. In other words, one side of the tap goes all the way through and the other dead ends. Take a knife and cut the dead end plastic out so that both wires can go all the way through. Place both the light green wire and the violet with white stripe wire in the tap and press it home with pliers. Be careful not to short the pliers to ground while doing this. I used a dab of dielectric grease in the tap just to be safe from corrosion later on. What this mod does is simply short across the low beam disconnect contacts of the multifunction switch. This will make the low beam filaments light as long as the light switch is turned on with the multifinction switch in either high or low beam position. I can now see the road better and it cost me $0.11 instead of $95.00. Questions are welcome.
Old 10-16-2005 | 06:20 PM
Rattle Rattle is credited for the last posted mod. I hope this helps DieselDork.
Old 10-16-2005 | 06:58 PM
MadDog01's Avatar
I've been happy with my EZ. Most of my driving is with a 27ft fifthwheel in tow. I tow on the lowest setting and am very happy with results. I'm buying a Van Aakan for my buddy, ( he is letting me use his backhoe ). He also has an EZ but wants to go to VA and 1.6 injectors. He thinks his EZ is going south.
1 John 1:9 If we confess our sins, He is faithful and just to forgive us our sins and to cleanse us from all unrighteousness.
Gary
GCSS
24
04-27-2010 02:27 PM
513yj
18
03-30-2007 12:49 PM
PapaPerk
08-23-2006 12:52 AM
jasonjones
03-18-2005 08:24 PM
Quick Reply: Simple mods & access. that you recommend
