silencer ring/ additional modifications
Old 06-22-2004, 02:26 PM
mitch@jc'sCTD's Avatar
Where at in the 1997 CTDs is the silencer ring located and how do i take it out? Does it hurt the motor or help it and does anyone have any suggestions on low cost modifications for a 97 2500 CTD
mitch@jc'sCTD
97 2500 CTD 4x4, bedliner, nerf bars, no cat or muffler
Old 06-22-2004, 02:38 PM
INJECTOR JACK's Avatar
Talking silencer ring
The silencer ring is at the air inlet side of the turbo, you have to
remove the snap ring in front of the silencer ring to pull it out leave the snap ring out afterwards, cheap mod's would afc adjustment, timing, installing a BHAF, exhuast. good luck happy BOMBING!
Old 06-22-2004, 05:04 PM
Turbo Deeezle's Avatar
Here's a stumper........
What is a BHAF ? afc adjustment ?
Old 06-22-2004, 05:09 PM
BHAF afc adjustment
A BHAF is a big honk'n air cleaner (cummins marine) you remove the stock air box and install the bhaf in place. The afc (air fuel control) is on top of the pump it controls the fuel rate to turbo boost to prevent smoking, you can adjust it to get more fuel early but you will also get smoke.
Old 06-22-2004, 05:13 PM
Wink
Thanks
Old 06-22-2004, 05:15 PM
One more ?
where do I get a BHAF and is it a noticeable upgrade ?
Old 06-22-2004, 05:20 PM
BigBlue's Avatar
Napa carries them. Do a search and you should be able to come up with the part numbers.
Old 06-23-2004, 10:05 AM
army_guy's Avatar
I have had my BAHF for about 3 months. I just took my first long trip with it (875 miles) and I got 18.3 mpg @ 70-75 mph. I also took out my silencer ring and it sounds really cool, like a mini semi. I would say it probably gave me 1 mpg. When you install your filter make sure you put in the heat shield. The pattern is on here somewhere. Phox Mulder or the Dr. probably know where its at. It cost me 2 bucks at the junk yard for the metal and 30 minutes to build.
Old 06-23-2004, 10:12 AM
Is there another name for the BAHF? I went to the napa website and they didnt know what it was so is there another place to get it or another name?
thanks
Old 06-23-2004, 11:20 AM
BHAF
It's a cummins marine air filter do a search for a bhaf on this site and you will probaly find the Napa part#
Old 06-23-2004, 11:29 AM
BBWD's Avatar
part number
thanks
Mitch:
Go to the tech facts section at the top of the page. The part numbers for 4 or 5 different manufacturers are listed there. You can get one of them from NAPA. Just give them the numbers listed there.
John (DH)
Old 06-23-2004, 02:31 PM
gsdog1's Avatar
BTW - if you use the NAPA part number listed in the tech facts (which is the right one) and enter it into the NAPA website, you get something silly like a toothbrush or some such nonsense. Take the part number to a dealer and they can set you up.
Also, there is a marine version of the BHAF, but it costs a lot more than the standard ones that most of us run.
Matt
Old 06-23-2004, 04:39 PM
guyssets's Avatar
Location: Different City each Week of the Year, Currently: Newtown Ct
is there an afc on the 2002 year ctd?
Old 06-23-2004, 04:58 PM
Talking afc
There is no afc on 24v's they have a boost sensor.
Old 06-23-2004, 08:17 PM
4doogie's Avatar
hey is the afc right on top of the pump? how hard is it to change? how much do i turn it? chris
Quick Reply: silencer ring/ additional modifications
