Silencer Ring
Silencer Ring
Hey guys,I removed the Ring off the 01 and it sounds wicked,but I'm wondering if removing will hurt airflow? or anything else? I pull travel trailers all the time and don't wanna find out the hard way.
Anything you all have to say would be appriciated.
Nope your good man, it actually allows more air into the turbo ( not much but it does ) and also helps reduce that dang turbo bark from letting off the throttle to quick under boost.
~Nick
~Nick
I was told years ago it was placed there by Cummins as requested by Dodge to quiet the turbo. It actually makes no difference in or out as far as performance goes. Like I said, I was told this by a Cummins mechanic right after I bought my truck in '99.
Registered
pull em out. i have removed dads and mine (back when i was running the stocker) and there was no difference in performance or turbo bark. Dont worry about it. pull it, sounds MUCH better!
It's held in by a snap ring. A screwdriver and about 2 minutes should take care of it. Just pull the intake tube, and pop the snap ring out, it will just fall out with it.
With it in or out?
IMO, it probably improves compressor efficiency slightly, but removing it should help reduce turbo bark by letting the MWE do it's job. Also, IMO the increase in whistle is worth the slight decrease in efficiency.
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
About 1/4 down this page shows the silencer ring and how to remove it.
It took me a little while and some frustration to get mine out because the screwdriver kept slipping. I ended up using some heavy duty pick tools, (They're like thick dentists tools which I got at wal-mart). Then I could lift the ring, hook it and work my way around.
Pull them out....but for God's sake....and your trucks....don't do it like this.
https://www.dieseltruckresource.com/...ad.php?t=96135
I have never seen such ........ lack of touch! Use two small, flat screw drivers, it is VERY simple.
