Sick of this electric lift pump bs...
#31
Overall zero probs with the holley blue (16-20psi w/a slight stretch in the spring) but for some reason my fuel psi has been increasing. I changed both the factory filter and my pre-holley filter....still 25-27psi. I went ahead and installed the regulator, backed it all the way out and now back to 16-20. The reason for the regulator is that fuel began leaking from the WIF sensor as I don't believe it's capable of handling higher psi in the filter canister. Just some info for those thinking of installing a holley blue and that you might as well install the regulator at the sametime as the pump.
Diesel Girl
18
10-06-2013 03:03 PM
cj5er
12-20-2009 09:19 PM
Pa outlaw
06-23-2004 09:30 AM
