Should I trade the Comp for Smarty?
Old 03-26-2008 | 04:20 PM
Mike D's Avatar
Originally Posted by haloman
Not anymore. Adrenaline is out dynoing that stack.
Prove it!
Old 03-26-2008 | 04:21 PM
haloman's Avatar
Originally Posted by Mike D
Prove it!
User RowJ did. IIRC 25 hp more
Mike D's Avatar
Originally Posted by MSquare
OMG! We agree on something!
Don't look up, the sky might be falling.
Old 03-26-2008 | 04:28 PM
Mike D's Avatar
I'm not convinced it's good data, runs were on a dynocom unit with water meth. Not trying to take anything away from RowJ.
I personally think it should take more than one truck and one dyno run before we can start making claims.
EDIT: I should also say, I hope Quad's box does out dyno the TST/Dummy stack. I'm looking for a reason.
Old 03-26-2008 | 04:32 PM
haloman's Avatar
See if quad will let you use one for TS. I'll help you with connections.
Old 03-26-2008 | 04:54 PM
Mike D's Avatar
I asked to be a beta but apparently he had enough testers at the time. I even voted for his Texas hunting team as a bribe to get a test unit, I should have held him to his promise.
Old 03-26-2008 | 05:09 PM
smokinstrokes99's Avatar
look in to the quadzilla Adrenalin box, quad has but alot of work in to this and from what iv read it is the best out there, i have its little brother and i love it
Old 03-26-2008 | 05:39 PM
AggieJustin's Avatar
I think the general consensus was that the Dynocom was generous by around 8% compared to the mobile DynoJet at Bully Dog a couple of weekends ago.
Not sure if anyone else ran an Adrenaline that day that also ran the Dynocom.
Old 03-26-2008 | 06:12 PM
Mike D's Avatar
8% is a lot when your talking about trucks around 500hp, difference of roughly 40hp.
Old 03-26-2008 | 06:15 PM
Most definitely. I didn't remember what RowJ's number was from the DynoJet, but I remembered figured his, Tyler's and Robert's numbers and they were all around an 8% difference.
Definitely a big difference as you go up the scale.
Old 03-26-2008 | 06:24 PM
Mike D's Avatar
RowJ did 598 w/water meth.
Old 03-26-2008 | 06:37 PM
Had to go look up the Bully Dog/ODRA thread.
RowJ did 543 on the DynoJet. 598 was on the Dynocom. So that actually worked out to be a 10% difference
Old 03-26-2008 | 07:22 PM
Mike D's Avatar
Yikes! I think back to back tests are in order along with multiple trucks on a dynojet before we can reach a consensus.
Old 03-26-2008 | 09:06 PM
scottsjeeprolet's Avatar
Boy we're getting way off track on this thread.
So i ran the Smarty on 6 and Comp on 3x3 tonight and WOW. Lots of smoke off the line but spools the HX35 really quick. Need a bigger charger. Can't wait to try it on sw8. My tranny don't like it until hits 3rd lock.
Still want the on the fly adjust ability.
Old 03-26-2008 | 11:39 PM
NoSeeUm's Avatar
I would wait (wait out) the new 2nd Gen Smarty upgrades before I traded a Smarty for a Comp. I don't think at this stage I could be happy with the performance of not using a fueling box. The Smarty can not compare in performance to the Comp.
Other than that the only reason I would do it would be if I was downsizing injectors / needed a boost fooler and I wanted to keep my set up really simple.
Personnally, I would recommend a Smarty to anyone running smaller injectors, not twins or large tires.
Jim
