Should I grind the AFC arm?
Just wondering if it is holding me back any on the rack tavel. I have a pretty deep ground #0 plate. Just wondering if i would benefit from grinding it down a hair.
Eric
Eric
Yes you will benifet, even more so if you shim your rack plug or swap it with a deeper one.... I am going to write up instructions tommorrow and make a post since there aren't really any around here.
I know how to do it all, just havent done it. And if I do anything with the plug, it will be swapping it to the mack plug. I have a timing kit, so loosening the pump up and pulling it back a little shouldnt be a huge deal.
mike_ward
08-26-2007 09:42 PM
