Short Shift Kits
Old 01-05-2005 | 06:06 PM
greenworks's Avatar
Question Short Shift Kits
I run a 5 speed and have been looking at several compnaies short shift kits to reduce throw. I have also heard of guys making their own by bending the stock shifter handle, it is likely that these kits are only a modifed shifter anyway since the gear still has to be moved the same amount anyway. Any thoughts or cheap ideas??
Old 01-05-2005 | 06:38 PM
Moose10's Avatar
What other companies make them besides BD? I've never seen any others.
It's my understanding that the "short shifter" just pivots at a higher point up from the tranny....yes - no ?
Old 01-05-2005 | 06:42 PM
CTD_Neil's Avatar
I have a BD short shift. The lever under the shifter base is longer than stock, therefore the shifter above the pivot point has to travel less to move the rod the same amount. Think of it like a teeter-totter from when you were a kid. The board was evenly spaced on the pivot point, and you and your friend would both rise the same amount. if you were to move the board over to one side, the short side would travel less but the longer side would travel farther. It would also be harder raise the person up on the longer side due to having less leverage on the short side, same with the shifter it will take more effort to shift, but the stroke is shorter. I had a HURST shorty shifter in a Mustang and the handle only had to move like 1 inch, it was cool.
Old 01-05-2005 | 06:50 PM
greenworks's Avatar
I have a guy in my local chapter with what I think is a DPP shifter same idea as the BD shifter? so I guess the guys on here spouting that bending the shifter are out to lunch
Old 01-05-2005 | 09:00 PM
mkubacak's Avatar
I have the BD for my six speed. Much better than stock, but I wished the NV5600 was as short and tight as a Hurst shifted T56.
Old 01-06-2005 | 12:02 AM
BigBlue's Avatar
Now that's a short shift.
Old 01-06-2005 | 08:26 AM
SHARPMACHINE's Avatar
How much are these short shifters and where do I go to look at them?? thank-you
Old 01-06-2005 | 11:22 AM
Kyle Graham's Avatar
BD-power.com has picture on site, check my signature
Old 01-06-2005 | 12:10 PM
Moose10's Avatar
Expect to pay over $200 from everywhere I've seen them I can earmark that much $$$ for other BOMBS until the truck is "done" imo.
Old 01-06-2005 | 03:26 PM
greenworks's Avatar
Do you guys think it gives you quicker and smoother shifts?
Old 01-06-2005 | 05:03 PM
MikeR's Avatar
The guys like me who have a bend shift lever aren't out to lunch....it's not a short shifter, it's only meant to put the shift **** very close to your leg instead of far away, that's a whole different subject.
I've had the BD short shifter in both 6sp and 5spd. It is a closer and quicker shift, but not smoother. I'm my experience it made the shift notchier, much like a powerstroke tranny.
Sorry 94-97 guys but the shortshift kits don't work on those tranny's. They have different shift towers than the 98 and up.
Old 01-06-2005 | 05:11 PM
Homestead's Avatar
Greenworks
Get hold of Kevin or Chris at DPS. They are making there own unit. They changed a bunch of things over the BD unit, way better!!!
236-9216.....They are just around the corner from the old Calgary BD shop.
They will look after you.
Old 01-06-2005 | 05:59 PM
signature600's Avatar
HA HA HA
That why I changed mine out for the newer one. Compared to the old one, this new one IS a short throw shifter.
I do have a BD unit I'm going to throw on this weekend. We'll see how I like it afterwards, this tranny is hard to shift as it is with the DD clutch and brand new synchros
Chris
BTW, Does this "DPS" have a full name or a website to look at. Thanks
Old 01-06-2005 | 06:27 PM
greenworks's Avatar
homestead that numbers ends up connecting to a fax? What does DPS stand for I did a search but nothing came up, what are they looking for the kit as far as $?
Thanks
Jason
