Shocks stuff.
Shocks stuff.
ok, I need some info, i'm putting in new shocks & I was wondering where & what you all got for shock mount bushings & also what size are the bolts so I can buy new ones.<br>any other installation tips would be great also.<br><br>DRecu!
Re:Shocks stuff.
My rancho 9000xs came with front shock mount bushings, washers and nuts. I reused the old bolts and nuts with no problems. Lots of WD40 2 to 3 days a head of time helps. Front shock if stock you will need a strap wrench to hold the upper shock from turning. <br><br>The drivers side shock is a PITA with very little room to work but the passenger is easier without the air filter and hose to the turbo in the way.<br><br>I did the backs first @.5 to 1.5 hrs and followed up with the fronts 1 to 2.5 hrs the second weekend.
EverydayDiesel
08-19-2007 09:38 AM
