Scotty or Vulcan.....Big Fuel Line kit?
Whos is better. I'm looking into the scotty or the Vulcan Big Fuel Line kits. I see that the vulcan is only 80 bucks, but scotty's is 199(canadian). Who's is more complete? Which one do you think will I will benefit from the most. I'm leaning towards the Vulcan because its only 80 bucks and well I could order it right now, but I know Scotty does top notch work. So I can't make up my mind. What do yall think?
Can't really comment on the Vulcan kit.
I have the Scotty kit, and LOVE it. Scotty's all about the BEST-- he will hunt down the BEST fittings, the BEST hose, and the BEST you can get. OR, he will have it made.
Note-- the Scotty setup uses STEEL fittings, the Vulcan setups uses Aluminum fittings. Which is stronger?
JMO
JMO
Eric at Vulcan machines his own fittings. His customer support is hands down the best I've ever received. The kit is 100% complete. The only other thing you'd ever have to buy to install this is a truck to put it on.
I don't have any scotty stuff, so I can't speak on that except to say he doesn't have many, if any, unsatisfied customers, either.
As for stronger, how much sheer force do these fittings see? Strength of the parts doesn't come into play unless you have the most cluttered engine bay with heavy crap swinging all around. And then you have other problems to deal with.
You'll most likely be happy either way. I dont consider either choice a bad, or worse, choice.
JMO
JMO
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Top's Younger Twin
I just finished stock piling 500 fittings and all the components for my kits today.
I also include a fuel pressure kit and biodiesel compatible hose with the finest Aeroquip components. I chose steel over aluminum to maintain the largest inner diameter.
Included also is a needle valve and one tapped fitting. The steel over rubber washer is also the best I could find for sealing. Its all -8 or 1/2" hose and fittings from the lift pump outlet to the injector pump. The kit also has 3/8" biodiesel compatible hose with clamp from the hardline on the frame to the lift pump inlet that has my metric to -6 push lock.
Hope this helps.
Scotty
Hope this helps.
Scotty
I broke one of the steel fittings that came with my scotty kit. Over tightened the hose. I went to a hyd. hose place to replace it. Aeroquip makes a fitting that would work. Compared the 2 fittings and saw a noticable difference in inside dia. with the scotty fitting being much larger.If you use the aeroquip fitting you might as well stay with the banjo bolt. Very happy with Scotty product and used 1 of the 2 extra fittings off the lift pump when I switched to a Fass setup throu the factory filter
If the quality of Scotty's kit is as good as his customer service and his drive for perfection then his has got to be the best. Speaking of fittings, I need to get off my butt and order those.
The only thing I will add on the Steel vs. Aluminum is vibration resistance. Vibration at high amplitudes can cause stress hardening in Aluminum over time, and depending on the frequency (how many times per second it has to move back and forth) the hardening can happen over years or hours. Steel can exhibit the same fatigue, but is more resiliant. There is a reason they use mostly steel fittings on Diesel injection system, save for the fuel canister I guess...
![Roll Eyes (Sarcastic)](https://www.dieseltruckresource.com/forums/images/smilies/rolleyes.gif)
Big Smoky
04-03-2006 11:55 PM
tempoffroad
03-27-2006 06:50 PM
latitud_rt
03-22-2006 11:52 AM
