scotty smart fuel
Old 07-30-2005 | 06:54 PM
Barefoot88's Avatar
scotty smart fuel
any body run this set up and is there any benefit
Old 07-30-2005 | 07:41 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I installed mine about 3 months ago.
I saw an fuel pressure increase of ~1 psi @ idle, ~2 psi @ 2000 rpm, and I haven't been able to pull it below 10 psi at full throttle.
Old 07-30-2005 | 09:32 PM
Barefoot88's Avatar
shovelhead
where did you guy yours the dtr has them for 175.00 can you buy them cheaper any where else
Old 07-30-2005 | 10:00 PM
Shovelhead's Avatar
I bought mine here at the DTR store.
Gotta help support the site to help us help you.
Old 07-30-2005 | 10:03 PM
Barefoot88's Avatar
if i buy it i will buy from dtr
Old 07-31-2005 | 12:27 PM
RowJ's Avatar
Excellent set up!
Benefits...
- Extends life of Lift pump by reducing cycling.
- Better Fuel flow at full throttle.
- Excelent quality
I had previous "Max Fuel Flow" system, with, I believe, slightly smaller fuel lines. Took me to 425 hp before fuel pressure got too low at WOT. Bigger lines should go to even higher HP!
Two years latter, when I went to a FASS...I removed it, one piece, intacked (including fuel filter canister)...and sold it for just what I paid for it.
RJ
Old 07-31-2005 | 05:42 PM
HOHN's Avatar
My Scotty fuel system will mw sustain 8 psi with Mach 4 (150hp) injectors.
This, with the factory oem lift pump.
Old 07-31-2005 | 10:10 PM
CTD NUT's Avatar
The Smartfuel exceeded my expectations for performance......with a stock high-mileage LP, I can barely pull fuel pressure down to 9 psi in top gear with the Comp on 5x5.....
hotdram
01-24-2006 05:47 PM
hotdram
01-18-2006 10:47 AM
cliffs03hd
03-10-2005 10:36 PM
MARKY MARK
35
03-01-2005 09:46 PM
Scotty
17
10-28-2004 01:39 PM
