Scotty II Questions
Originally Posted by red70ragtop
Scotty's web site said he was on vacation for June. I'm not upset about it or anything, I'm actually anxious to get it installed. I'll try cleaning everything off for the cone issue, and try to get the reinforcement ring issue straightened out whenever I can get in touch with Scotty. I'm sure it's gonna be great, that's why I bought it. Sometimes mistakes happen.
![Exclamation](https://www.dieseltruckresource.com/forums/images/icons/icon4.gif)
For the fittment of the end cone cover....
The problem is excess oil and also some pressure from the outer foam element.
After you clean up the end of the filter, push the foam back slightly.. Then using some emery cloth or sand paper, rough up the inside edge of the end cone cap. Once you rough up the end cone cap and make sure the rubber end of the filter is clean, the cap will stay in place better. You should NOT RUN THE FILTER WITHOUT THE END CAP.. This aligns the filter in the housing for proper fit.
I had the same problem with the end cap.
AS for the the ring for the filter, If you have some excess 4" PVC sewer pipe, get your hack saw and cut off about 2" worth. Sand off the corners and install into the end of the filter before putting the hose on.
I hope this helps..
I hope this helps..
I got the cone placed where I wanted it to be and used small scrws to secure it in place to the outer housing. When claning the filter it slides nicley into place. This is with an UNI filter.
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
Oily Turbos
Originally Posted by caper
Thanks for such quick replys, is that red foam the filter or a pre filter /?? Does the oil get sucked into the turbo like my POS k@n did.
Since the truck was brand new, I have been running stock filters (DRY, NO OIL). When I pulled it all off to install the S & B, I couldn't believe how oily it was! I've heard guys rant about the oiled (K&N) air filters and how crappy they are and how they oil up the turbos.
I'm thinking it may have less to do with the filters than people think.
Originally Posted by y2kram
I have a couple pics of my turbo with the hose off. Notice the oily surfaces.
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
The foam is the pre-filter, the inner is a pleated gauze filter.
I haven't had any oily turbo problems from the never UNI filter.
The hole (If you decide to drill it) is located where the filter housing touches the airbox/firewall area.
I haven't drilled the hole yet and I saw approx 50* drop in EGT.
![](https://www.dieseltruckresource.com/pics/data/500/19529Gallery_Scotty_II_Air_System.jpg)
Just do it.
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
Maverick2001
03-01-2006 05:55 PM
hellotbone
12-09-2003 12:32 PM
thecatsfan
15
03-14-2003 10:21 AM
