Scotty II Questions
Scotty II Questions
Where to buy and is it worth it. I have a BHAF now and sometimes after driving truck I'll pop the hood and feel the filter and its HOT and yes I have a heat shield. I want cool air, what kind of filter goes in the scotty ?? Are they oiled or expensive to replace.Thanks
You can get them through the DTR store. I love mine, it came highly recommended by a lot of guys here on this site. It has an oiled foam filter. Works well, gives you plenty of cold air, and sounds good too.
The foam is the pre-filter, the inner is a pleated gauze filter.
I haven't had any oily turbo problems from the never UNI filter.
The hole (If you decide to drill it) is located where the filter housing touches the airbox/firewall area.
I haven't drilled the hole yet and I saw approx 50* drop in EGT.
I bought a Scotty, drilled the hole, went to install it and found out I was given the wrong diameter reinforcement ring and filter for the hose I have on my turbo. I'm using a BHAF now. I gave the wrong filter and ring back and was given the proper diameter filter, but no ring. I can't get the hose to stay on the filter without the ring, and I also can't get the cone to stay on the other end. The fit isn't snug enough for it to stay on, so every time I try to slip the filter into the housing, the cone falls off. So, I'm on hold until I get the right ring and figure out what to do about the cone. I guess I could just leave it off. It also seems like there should be some sort of grommet to retain the housing in the firewall hole. But I haven't been able to get that far. It should be a really simple deal to put this in. But that has not been the case for me. That's about normal. I look forward to getting it figured out, because it looks like a great way to get a cooler air charge to the engine.
Have you contacted Scotty regarding your fitment troubles?
red70ragtop,
You should contact Scotty directly......he will get you fixed up pronto. Scotty has excellent customer service and he prides himself on that. Persistent problems like this are not typical and I doubt that he would be satisfied until you are.
Originally Posted by caper
Thanks for such quick replys, is that red foam the filter or a pre filter /?? Does the oil get sucked into the turbo like my POS k@n did.
On cutting the hole, I did on mine and it was a little loud. I would shut the hole when I didn't need the extra air. A "TrukLite" round 4.5" tail light grommet works great as a seal around the hole to the Scotty (you can get them from Napa for about 2-3 $) and you can also get a 4" test plumbing plug for about $3 from Lowe's or Home Depot to fit inside that grommet and close the hole to be quiet. When you are towing or drag racing and need the extra air, loosen the wing nut on the test plug, pull it out, and whaaalaaa, you have your extra air again! BTW, I saw 100 to 150 degrees of additional cooling from the Scotty.
Scotty's web site said he was on vacation for June. I'm not upset about it or anything, I'm actually anxious to get it installed. I'll try cleaning everything off for the cone issue, and try to get the reinforcement ring issue straightened out whenever I can get in touch with Scotty. I'm sure it's gonna be great, that's why I bought it. Sometimes mistakes happen.
