Scotty II ???
Scotty II ???
Now that the warranty is over I’m thinking of installing the “Scotty II” air intake. I have the “Jakebrake” Exhaust brake already installed is there a conflict for space by using both of these together?
Also I’m running a K&N with the stock intake box . Should I see any increase in MPG?
I don't know about the Jake Brake, but I have the Pac brake mounted on the turbo elbow and it is no where near the Scotty II as far as being in the way. I really wouldn't look for MPG gains out of an air intake system unless your current set up is real restrictive. The importance of the air intake would be to help lower EGT's.
Originally Posted by bigfoot
My main concern is where do you cut “the hole “. The Jake’s controls are mounted on the fire wall.
hellotbone
12-09-2003 01:32 PM
thecatsfan
15
03-14-2003 11:21 AM
