scotty air ??????
Old 09-20-2004 | 10:57 PM
taken5875's Avatar
Question scotty air ??????
how loud is the noise and is it worth putting up with it . or is there ways to keep the noise down . trying to do it right the 1st time thanks for any feed back..
Old 09-21-2004 | 06:59 AM
hotdram's Avatar
taken,
According to your sig, the only bombing you have done is a straight pipe. According to the Wildcat website the Scotty was: "Designed for working and performance enhanced Dodge diesels....". If you do not have major performance mods, I do not think you will see the EGT reduction mentioned, I believe Scotty will be the first to tell you that.
~Rob
Old 09-21-2004 | 11:16 AM
infidel's Avatar
The turbo whine in the cab if the Scotty firewall hole is cut is unbearable for some folks including myself. Not so bad just tooling around town but on a long highway cruise it will drive most people nuts. I've had passengers ask what's wrong with my truck. Too bad because it's the best filter system out there.
Good news is the TAG can almost totally eliminate the noise and offers other benefits as well. Scotty and TAG are an excellent combination.
TAG info here> http://www.dieselpowerproducts.com/tag
Old 09-21-2004 | 11:52 AM
jthorpe's Avatar
DTR Founder
Interesting. This is the first time I've read about TAG. Very interesting reading.
Old 09-21-2004 | 08:36 PM
taken5875's Avatar
yes she is only strait piped but i plan on a comp soon right after the gages
Old 09-21-2004 | 08:46 PM
taken5875's Avatar
what good is the scotty with out the hole??? any better flow than stock? if some one could point me in the right direction to a good in take system it would be helpful
Old 09-21-2004 | 09:09 PM
amartinson's Avatar
If you are serious Jack, there has been some really good discussion about the TAG in the past.
Such as HERE .
And a pretty good "real world test" by Infidel HERE .
That ought to keep you busy for a while.
Old 09-21-2004 | 09:12 PM
Scotty's Avatar
Top's Younger Twin
The Scotty will work better the more power you throw at it.
You can also put the insulation flap back over the cowl hole when you want if the noise is too loud. The TAG allows pretty much anyone with sensitive hearing to use it wide open with both inlets.
You will see some reduction in EGT with just the fender inlet but optimum is with both inlets.
I will not suggest the Scotty if you plan to stay stock or near stock...the BHAF does great up to about 75 added HP. The Scotty will out perform all others out there. I know this from testing and from folks that call and order and tell me what else they tried.
We are going to be releasing the new CUSTOM for the Scotty Systems UNI filters very soon. Prototyping and testing always takes longer then planned. A dual stage foam filter that is showing even greater egt reduction then what has been used previously. higher quality overall too. Same filters approved and used in the fine silt of BAJA racing.
Of course I am bias to this product. It works as I say it does.
Scotty
Old 09-21-2004 | 10:39 PM
mattgbank's Avatar
Has anyone tried cutting a hole in the firewall like you do for the scotty, but while using a bhaf? im shure its not as good as the scotty, but it might be better than just the bhaf with no hole. It should provide more cool air under the hood.
thanks, Matt
herb
07-18-2008 08:25 AM
nfsommer
04-16-2007 09:21 PM
hellotbone
12-09-2003 12:32 PM
CTDCAL
03-31-2003 01:43 AM
Mopar_Mudder
30
02-17-2003 04:18 PM
Quick Reply: scotty air ??????
