Scheids DV's.. CRAZY!!!
Old 07-15-2005, 07:07 AM
storx's Avatar
can we get a website to these DV's i cant seem to pin point a webpage for them to easy.
Old 07-15-2005, 07:56 AM
CTD NUT's Avatar
Piers, Schieds, Haisley and others all deal with big DV's.....any shop into P-pumps should be able to provide some big DV's......FWIW, DV's are only for P7100 pumped CTD's......they have nothing to do with the VP44 on 24v's.
Old 07-15-2005, 08:05 AM
CTD NUT's Avatar
Originally posted by Stamey
What about screwing the AFC back to where it is supposed to be? I can handle it not taking off like crazy, since I usually spool up (power brake) before taking off if I'm racing, anyway.
Thanks,
Chris
You should leave the AFC housing full forward but use the spring tension adjustment to tune your rate of boost enrichment.....You will be able to come to a compromise. Leave the housing full forward.......if you pull the housing back too far, it is possible for the AFC rack to limit WOT governor arm travel - and we don't want that!!
Old 07-15-2005, 10:57 AM
Lil Dog's Avatar
Wow, this sounds like a good upgrade... If you can get the low end without the big injectors I would be all for that.
I would think you could use the zero boost and spring starwheel adjustments to control the smoke to any level you wish.
Hmmmm...
Old 07-15-2005, 11:59 AM
CTD NUT's Avatar
You can use the AFC spring tension adjustment to a point to help with low boost smoke when using big DV's but inevitably, you will have more low boost smoke when you stomp on it.....if you tune all the smoke out, you won't have a very large power increase from the DV's. Also, from my experience, I would not turn the zero boost screw out any further than stock as you will notice a power loss off idle.
Old 07-15-2005, 01:59 PM
Lil Dog's Avatar
I have alot of other mods to do first, but this seems like a nice step before getting the big injectors.
I have had to move the zero boost setting in after the plate install and AFC spring install. The instructions for the AFC spring were to back it out, but I found just as you said, the off the line punch was gone. I have since gone in about 2 turns to get it so I can leave the line with some respectable pull.
Thanks CTD..
bigd6.6
Competition / Pulls / OffRoad
08-30-2006 12:48 AM
TRCM
12-19-2005 01:38 PM
Bobcat698
07-19-2005 04:46 PM
Dieseldude4x4
49
08-23-2003 07:22 PM
Quick Reply: Scheids DV's.. CRAZY!!!
