S400 specs??
Call Haisley Machine. The only other thing is that with your set up you would want the 80mm exhaust housing. you can also get them in I believe 110,120,130? I also think that they all have a three inch inducer so if you are planning in pulling in the street class you will have to get a shim from haisleys to get it down to the 2.8 limit.
The s-400 I ran last year had a 2.5 compressor wheel with a 110 exh. housing. I wouildn't go any bigger exh. housing. Mine didn't lite until 2500 rpm with almost an identicle set-up to what you are running. With a torque enhancer D box I only got 43-45 lbs of boost, never had a problem with the HG at that level
thanks for the info...i plan on going back to haisleys next weekend again when i get it and see what van has to say about it...what injectors were you running 24vpuller?
same as you, I don't believe they were big enough though. Haisley's charger has a 2.8 wheel and lites a little easier. A guy back here runs one with an auto and a Redline box with the same injectors as you and he does really well
so what do you think about the 80 housing on the street as a single? probably be too laggy, and i rarely ever pull trailers. i dont know anything about it yet, i bought it off ebay so it may even need a rebuild
Sixpack73
15
07-17-2009 07:31 PM
06RAMCTD
0
12-19-2006 04:15 PM
