s400 as a single
Old 09-08-2007, 11:06 AM
tinman1911's Avatar
s400 as a single
my turbo took a dive so now i need another
i was thinking about an s400 i dont want twins and i dont want to spend $1500 on a turbo any suggestions
Old 09-08-2007, 11:41 AM
chrleb1's Avatar
Good luck. It'd never light, maybe with tons of NOS. It's lag so bad, then when you shift it won't want to come back on.
Find a 64/12. That'll move some air for you.
Old 09-08-2007, 02:01 PM
24valvepuller's Avatar
Scheids had a s-400 hybrid that was more of a s-300, freind of mine had one it worked pretty well. A full size s-400 is too big for dailey driving, I got one on my truck right now. 1800 rpm before anything in the way of boost with a LOT of fuel, runs about 900 degrees down a flat road at 45mph and hotter as you get faster. forget about towing anything but a log splitter
Old 09-08-2007, 08:45 PM
Bosshawg600's Avatar
we think my buddie has one (numbers filed off) does take a while to light but when it does WOOSH. Peghe boost guage almost instantly and runs like a raped ape. He's Cowboystoys on here. Truck was built for pulling but he drives it every day and pulls a bit and doesnt run that hot. but it does smoke like a freigt train!
Old 09-08-2007, 10:46 PM
97' CTD's Avatar
Im getting ready to run a S-400 on a daily driver you just need to know how to build Em'! More to it than stripping one off a big rig puttin it on your truck and driving away happily.
Brandon
Old 09-09-2007, 09:28 AM
he said he doesn't want to spend 1500 on a turbo, you ain't going to build a s-400 for much less than that
Old 09-09-2007, 09:41 AM
PourinDiesel's Avatar
Go ahead everyone seems to think an S400 is good on a daily driver with minimal mods I say knock yourself out and let us know how it runs!
Old 09-09-2007, 11:09 AM
Bjans's Avatar
Industrial injection will sell you a brand new one out of the box for $800 bucks
Old 09-09-2007, 11:56 AM
wana12v's Avatar
I run one, but its not an out of the box combination. it has a 2.7 compressor and it has an s300 exhaust housing machined out to fit. it is on my daily driver, but i also have a camshaft. it produced 621 hp at 3000rpm. it is laggy but with proper afc tuning it does not excessively smoke at low boost. cruise temps run from 650 to 900 depending on the outside air temp.
Old 09-09-2007, 12:18 PM
97' CTD's Avatar
Charleb1 said it would never light. I WASNT telling him to buy one, I was just stating to the man asking the question that it doesnt take NOS to light one and for his info bank their is many mods to make a larger frame charger work on a Daily Driver if he didnt already have this information!
Brandon
P.S. How is the truck runnin Justin seen the dyno numbers very nice !
Old 09-09-2007, 01:50 PM
Thanks,
Its still in one piece!
Old 09-09-2007, 05:15 PM
Rods's Avatar
I run one but it has a small inducer 65mm I had a small housing cut to fit its around a 12cm , and it lightes b4 2000 with M6+ egts were 1400+ @ 55lbs . I done it just cause I was tired of breaking shafts ..
Old 09-09-2007, 10:48 PM
Ph4tty's Avatar
Is that the titanium compressor?
I'm thinking I might try a small s400 next, but I'm going to need some contact info it could be pm'd.
Stupid phat shaft is seeping oil Maybe thats why I can't make but 35 lbs now
Old 09-09-2007, 10:56 PM
Originally Posted by Ph4tty
Is that the titanium compressor? How much boost are you seeing?
Another S300 bites the dust....Leaking oil=worn thrust bearing, rebuild it before its too late.
Old 09-09-2007, 11:02 PM
tinman1911's Avatar
thx for the replies guys
and as for a s400 city diesel sells them for $650
still havent found a turbo yet
Quick Reply: s400 as a single
