s400 Exh. Housing Sizes
How does a s400 exh. housing size of 1.32 a/r equate out in cm2? Is it 20cm2 or what ? Is there a conversion to use that can tell you this?
But you can't really compare that area to a Holset are because I have no idea WHERE holset measure the sectional area that they quote.
jh
I'm needing to know if I think I canget this thing spooled up? It has a 2.7985 inducer size and the exh is 1.32 a/r. Wonder if how hard it would be spin it?
That calculates to roughly a 1.847 area (assuming inches)
In cm2, that's about 11.91Cm
That doesn't make sense. Are you quoting the inducer for the COMPRESSOR side? remember, you need TURBINE major diameter for A/R purposes, afaik.
Sixpack73
15
07-17-2009 07:31 PM
GR40RCapri
10-28-2006 02:36 PM
