S300G Opinions?
I appreciate the input guys! I wasn't aware of the specs on that particular turbo and even if I was not sure it would have done me much good, as I'm still wet behind the ears(to say the least) when it comes to turbos.
Lets put it this way, your stock HY 35 can push somewhere between 40 and 45 lbs of air per minute. An HX 35 comes on stick shift 01',02' and all 94.5'-00' and can push 45-50 lbs per minute. And an S300g with 57mm wheel can push 61lbs of air per minute for 425-450 HP
Your HY is good for 300 HP with reasonable egts, more if you push it. HX 35 is good for 350 HP, more if you push egts high.
Definitely. I had Jammer 2's, HRVP and Smarty (albeit on 7), and the HX35, it would get warm, but nothing that you can't control. You'd have less fuel than I did, and more turbo. Should be a good combination.
What about this turbo from HTT;
http://cgi.ebay.com/ebaymotors/High-...QQcmdZViewItem
Its a 62mm Compressor, 65mm Turbine, 13cm SS Wastegated Turbine Housing and supports the kind of power I want when its all said and done. Any thoughts on this turbo?
Big Blue24
12-17-2007 09:42 AM
BigBully
11-27-2006 08:47 AM
FDPOWER
05-27-2006 03:02 PM
SuperDave4x4
22
11-16-2005 06:10 PM
