RV275 injector install help
Good info, but I'd do the test run on #1 since it's accessable, then do the pita #6 and come forward. I left the engine hoisting loop off mine when I did my injection pump so that was one less thing I had to work around.
Well, I got it done today. Took about 3 1/2 hours. Took my time and everything went very well with no problems. The back two injectors were harder to get out and put back in but just took longer. Bumped the starter 3 times and then it finally fired up. Took it for a spin and I can feel more power at WOT runs. The old injectors looked pretty sad at 82,000 miles. The tips were completely black with crusted black stuff around the spray holes. Not sure if this crud made a difference in performance and mileage.
piperca,
I've got a big smile on my face right now after my short 3 mile test drive. I just put bigger tires on about a month ago and I could tell I lost some power. These 275's took care of that. I've been wanting some 275's for a while and have been putting it off but the new tires pushed me over the edge to get the 275's. I was a little worried about my stock tranny but after the test drive, all is good. It handled it just fine. I'd really like to get an Edge or Van Aaken box but I know my tranny would not like that. In time I'll have a built tranny and a box. Back to your question...yes, I think $295 was well worth it. Can't wait to get up in the morning and test it out on my way to work!
Ya know...I didn't even look. I'll check it out tomorrow. With the stock injectors, I can't get it over about 17 1/2 to 18. No boost fooler. I thought about adding one but figured if I got an Edge box, I wouldn't need one since it comes built in. It's going to be awile before I get the fueling box since my tranny is stock. I would tear the *#%& out of it. Maybe I should add the boost fooler? Anybody know if it would help?
I can hit 19 psi at WOT, pulling a grade, empty. I thought that was bad! I think she'll set an overboost code at 21-22 psi, so I've been told. I thought the RV275's alone would peg that ... no?
BigBlue,
Now you've got me thinking about that EZ. I can slip the tranny by nailing the throttle at low rpm's so I better not attempt more power until the tranny upgrade. I know I'm going to want more soon though. I've been on DTR for a couple years listening to everyone putting on fueling boxes and injectors...I just can't take in anymore!! Anybody have an extra $3,000-$4,000 laying around that they don't need?
