running two EGT senders to 1 gauge
Old 09-19-2005 | 11:57 AM
darrenG's Avatar
Anyone running a pre and post sending unit to the same gauge? I'm curious as to how / what materials? I know I'll need a switch, the sending unit & some wire....maybe some elbowgrease. I'm not sure what the requirements for the switch are.
Old 09-19-2005 | 12:57 PM
67HotRod's Avatar
I was considering the same setup, but not sure how far off the gauge would be with the added wire/etc.
Diagram in my pics.
Old 09-19-2005 | 02:07 PM
LanceD's Avatar
I did it with mine, all you need is a switch that is DPDT 2 position switch, It will have 6 prongs on the back. you wire one sending unit to the two prongs on the top and the other one to the two bottom prongs, then the middle two prongs go to the gauge.
Old 09-19-2005 | 02:10 PM
67HotRod's Avatar
LANCED: Did you notice any difference in readings with the switch installed? I'm thinking the added resistance of the switch, etc would throw off the gauge, not sure how much.
Not the big question, how much of a difference in temps do you see pre & post turbo?
Thanks!
67HotRod
Old 09-19-2005 | 02:40 PM
BigBlue's Avatar
When I did this the temps were pretty much the same until I stood on it and then they would vary as much as 500*. Even when cooling down the temps were pretty close. Within 50* of each other.
Old 09-19-2005 | 06:15 PM
Saxet Nomad's Avatar
Thanks!
67HotRod
As long as you get a "decent" switch the resistance should be minimal through-out the life of the switch . Don't go to Wal-Mart and buy a $1 switch and expect it not give you trouble...
Old 09-19-2005 | 10:18 PM
LanceD's Avatar
same here. its fun cause you can switch it on the fly, but keep your eyes on the road
Old 09-20-2005 | 08:33 AM
RowJ's Avatar
Isn't the length of the wire from the probe to the gauge critical in reading accurate voltage (temps)?
RJ
Old 09-20-2005 | 08:52 AM
Gene007's Avatar
Where can I get just a probe?
Thanks,
Gene
Old 09-20-2005 | 09:09 AM
RowJ's Avatar
Probes are gauge specific. What Make & model?
RJ
Old 09-20-2005 | 09:23 AM
LanceD's Avatar
I got my auto meter gauge and probes from summit racing
Old 09-20-2005 | 09:42 AM
4x4dually's Avatar
Switching Thermocouple Wires
I'm not so sure that you can just install a switch in between a thermocouple probe and a gauge. Thermocouples rely on a voltage differential created by to dis-similar metal conductors. I'm not sure how a set of tin plated copper (I'm assuming) contacts and solder joints or spade lugs in the middle of the conductors will affect them. Apparently it works, but I'm thinking it won't be near as accurate. Has anyone taken side by side readings with two gauges with one on a switch and compared readings? Just curious.
$.02
Old 09-20-2005 | 09:47 AM
darrenG's Avatar
I can find the sender - where do you find a good switch?
Old 09-20-2005 | 09:53 AM
Gene007's Avatar
I just purchased another isspro set up (R607T), decided not to run the switch. Have to buy a three gauge pod now The wife will be happy about that.
Thanks Gene
Old 09-21-2005 | 01:59 AM
Sea Bass's Avatar
I've been thinking about this for sometime now. I installed my thermo post turbo because I didn't know any better. Now, I'd just like to add another thermo on the manifold but I like having the post turbo thermo for shutdown temps. I found these switches but haven't talked to anyone about them yet.
http://www.frostalarm.com/cat/p38.html
Doug
