Running a single battery now
I am running a single battery now. I just picked up an Odyssey 1700MJT and this thing works awesome. My optimas always cranked slower in the morning but this thing doesn't care how cold it is. Its pretty big and required a little "fitting" to get into the battery tray and I might redo the hold down but otherwise I am super impressed with this thing. For those of you that don't have as much engine compartment room as us twin guys this is the way to go.
I have been running a single for more than 2 years. I used a group 31-5 xhd. It does require trimming of the plastic battery tray to fit. Has started unplugged down to 15 degrees with no problem. That Odessey has a lot more cranking amps( Mine is 1100) So you should have no problems unless you visit the artic circle in winter. Let us know how it works over the long term. Tim
Originally Posted by Jambbii
I got mine for 220 at a place called Batteries of Az. I think summit racing has them also.
I wish a had seen this a year ago.
You can also get them here. http://www.mrbobsdistributing.com/
Originally Posted by WideOpenThrottl
whats the cranking amps at 0*F?
tim.
tim.
http://www.odysseyfactory.com/docume...5-001_1005.pdf
jesussaves
11-07-2010 07:55 AM
EdmontonCanada
10-10-2008 12:37 PM
