Running a non wasgated turbo on your 24v
I want to know has anyone run a non waste gated turbo on their 24v? I have one that Im thinking about putting on my daily driver. Thanks for all the input guys!!!!!!!
thats real close to a T70 MP says it has a 67 wheel the turbine is like a p trim so its real close the a/r is 72 and its divided mine was not that hurt.. So it should do decent 400+ shouldnt b a prob with the wright fuel , i had there GT45 but i traded it off b4 i got to try it . There is some bad rep about MP they tend to break easy ,,,hmm the dp should b a 40 size around 3 1/2 to 4
I ran a KSB-1 (Borge-Warner S300 derivative) for almost 2 yrs, witn no wastegate. It had a 64mm compressor bore and on the street, it was excellent up to 475 hp. Got a little hot at WOT and would push 51 psi boost if you stayed on the throttle, but around town it was excellent!
No personal expirience or knowledge of the Master Power turbos. Without a wastegate, and even with one, I would shy away from unproven brands.
RJ
RJ
I run a TAD-B1 with the wastegate disable, the tube always blew off anyway so I just plugged it. hits 48 on a cool night, but i blew my headgasket a few weeks ago. be careful of your headgasket over 40psi, some last some dont
