Running boost gauge off of WG elbow?
Since my Waste Gate Acuator is leaking I've kinked the hose that used to feed it.
Now I've got a boost gauge I'm thinking I can put that elbow to use and run my boost gauge off of it. The stock elbow should give should give true numbers right? It looks like the TST adjustable boost elbow might give a false reading, but stock I'm okay?
If anyone knows one way or the other let me know. Otherwise I'd love to know what kind of boost numbers are 'normal' with my truck seen below making an optimistic 180/420. Unloaded, what would be the max boost I would expect to see under gentle acceleration, normal and WOT?
Thanks!
Thanks!
My gut says that in a pressurized system volume of flow may vary but pressure wouldn't unless there was some kind of pressure regulator involved, for instance in the elbow. There could be something in the aftercooler etc. but that would be a pretty counter productive design.
But I plain old don't know.
You know there's a pressure change when the hot off the turbo air gets cooled down in the aftercooler...and when hot liquids or gasses cool off, there is a pressure drop.
There is a difference between manifold pressure and turbo housing pressure. The manifold pressure will be the most accurate since its down stream from the inter-cooler and all the plumbing, plus the volume is much larger than the compressor housing. I think a more accurate location on the turbo would be the outlet anyway.
Fritz has some good info on the turbos, some might be rudamentory for you but its a quick read anyway:
http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
dodgediesel
14
12-14-2006 09:54 AM
RockcrawlingTJ
07-22-2006 05:11 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
