Routing ISSPRO trans temp wire, where?
Old 02-22-2007 | 07:28 PM
fade94's Avatar
Exclamation Routing ISSPRO trans temp wire, where?
I have the ISSPRO trans temp gauge. I also have the replacement trans line with the fitting in it to mount it. I have the wire plugged into the probe, run under the oil pan and up to the firewall. But, there is not enough wire to run to my gauge. They sell an extension wire but if I don't need it, I would rather not buy it. How do you have your wire ran using the stock amount of wire?
Old 02-22-2007 | 08:11 PM
1ST CUMNZ's Avatar
I had more than enough wire to run inside cab,but if you don't just and as much as you need.Don't forget solder,heat shrink.Just my 2 cents
Old 02-22-2007 | 08:22 PM
fade94's Avatar
I got it. I ran it behind the head and then down to the fitting. THANKS!
piston
02-03-2005 11:37 PM
RAM2940
01-11-2005 12:38 PM
kd460
02-16-2004 09:49 AM
SilverDiesel
01-01-2004 03:14 AM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: Routing ISSPRO trans temp wire, where?
