Rip's twins vrs BD twins
how good are these for the 2nd gens and how much power can they support safely (and unsafely), for rips it will be a s-300 top thanks guys. and also which kit do you belive is higher quality?
The Guru
How much power you going to run? You towing? How is Rip setting up the twins? The s300 over the s400 is pretty sweet and comparable to my HX-40/BTH-3b set-up. If you want to buy a set of twins buy mine, I'm selling them for $2500. I just put in fresh new turbos and they have less than 10k on them. You will have tons of air and they spool pretty good.
rips setup is a s300 on top (which i already have) and a s 400 on bottom, from bd i will be getting the upgrade kit which makes its price comparable with rips setup and ive heard of good power from both.
To get the most out of that monsta pump you should get the s400 instead of the s300. BD has a set of race twins with the s400, but they're some kind of rarity last I heard.
The Guru
How is rip setting up the S300? If it was me I would put a Garrett 3788 on top the S400 or the 3B. It would out spool the BD set-up and have better egt's. I should have a set put together here shortly. I can still use my existing air tubes and my old primary, I just have to put together a hot down pipe from the Garrett. It looks pretty easy project.
Mopar_Mudder
30
02-17-2003 04:18 PM
