reworking the factory waste gate housing.
i was thinking about reworking the factory housing to make the waste gate bleed pressure from both sides. i am just worried about how i want to do it. it would be simple to cut a passage from one side to the other right across from the waste gate opening. does anyone have a reason not to do this?
not at my fueling levels, i want to connect the front and rear passages of the ex housing. the factory only bleeds off from the rear side, on hx35 anyway, the front 3 cylinders are never wastegated. hy9's are waste gated f&r from holset.
Have someone drill the flutes under the flapper valve, you could drill a hole so it will vent all 6 cyl's, problem is it weaken's the housing and will crack with high temps.
If the housing was bigger like a 16 then this would be ideal.
Jim
Jim
i was thinking about doing it to my 14cm wastegated housing i have now. i am building a set of towing twins and want to see how well they will work without a external waste gate. i figure i will open the waste gate a bit and balance it front to rear. i am still going to put in some blow off valves to keep it in check, i hope i woun't need them. mike
Haulin_in_Dixie
23
03-31-2005 11:53 PM
