replaceing factory controls with a lockup switch
Old 09-08-2006, 11:27 AM
Mcmopar's Avatar
Originally Posted by hamilton71801
If I do this, would it help me when pulling up mountains in 1-3rd? I know that when I made this pull last year, the TC would not locked up and created a lot of heat. When decending the mountain, I would put it in 1st or 2nd and "try" to let the trans hold me back. This also heated it up. Will a lock-up help me or would I just be pissin in the wind?
It will help-you can control lockup in Drive and OD. Unless you have a moded VB it will not lockup in 1 or 2. Mine has been modded so I can L/U in 2-3-OD. It will help "slow you down" when locked, but you need to be aware that if the T/C slips you can kill it.
Old 09-08-2006, 11:31 AM
huckstep's Avatar
I don't have personal experience with this but my understanding is that yes locking the TC will reduce Trans temp. However I'm not sure how well the stock TC will take being locked under heavy load. I'd guess you'd be okay locking at above 30 mph but that is truly a Wild *** Guess. For me, I'm waiting 'til I know I have a TC that'll take it.
As far as engine braking goes it may reduce temp but I don't think you'll get much braking either way, apparently diesels just don't engine brake like gassers. I do know a TC lock helps a true Jake/pac brake work and may even be required for full functionality.
Old 09-08-2006, 12:21 PM
CSAGrey1's Avatar
It is my understanding that it will help alot during towing as well as if you want to go NOW!!. I do not have mine yet (and I'm sure someone will correct me if I'm wrong) but I think you hit the switch as soon as you get into 2nd. It will up shift 2-3 and 3-4 in lockup. Once you are in 4 (OD) it will not down shift so you have to take it out of lock up or you will stall the motor. If you have OD turned off or have not achieved OD it will down shift from 3-2 and 2-1 but you will again need to disingage it or you will stall. Hopefully someone will stop by and correct any part of that that is wrong so we don't have to learn the hard way.
Old 09-08-2006, 03:32 PM
Mcmopar's Avatar
NOT RECOMMENDED on a stock transmission!!!! Only lock it up once you are in D or OD. Locked shifts have broken many an input shaft.
Old 09-08-2006, 05:11 PM
CSAGrey1's Avatar
Can the D - OD shift be done in lock up without busting shafts? What VB mod need to be done to allow 2nd gear lock up? If I have to do more moding to my VB and can't make at least a d-od shift locked I just may be wasting me time running the wire.
Old 09-11-2006, 09:45 AM
Mcmopar's Avatar
Your stock VB will go from 3 to OD locked up with a switch. It is a "noticeable" bump, but not to drastic. Overtime I think you will be tempting fate on stock shafts. If you want to lock up in all gears or whatever, I would go buy a good VB.
Old 09-11-2006, 06:49 PM
S.Dodge's Avatar
i have a stock TC but I also have a DTT valve body, is there any way to get it to lock up in 2nd like it does in 3rd, the stock TC is so inefficent(sp) when it does lock up it just like hitting the power band on my dirt bike, I wouldn't want it to shift locked up for fear of breaking a shaft, is there any way to do this?
Old 09-11-2006, 09:03 PM
CSAGrey1's Avatar
What is the difference in VBs that allow the 2nd gear lockup? I don't have an after market but mine is kited. Is there a mod that can be done?
If it breaks it breaks I will have a legitimate excuse for a full build!
Old 09-11-2006, 11:06 PM
S.Dodge's Avatar
Is there any way to get the TC to lock up in 2nd, 3rd, but have it unlock to shift to avoid breaking a shaft. Is the TC locked when it shifts from 3rd to OD? Or is there at leasta way to get it to lock up sooner in 3rd maybe right away?
Old 09-12-2006, 09:54 PM
srt20's Avatar
My trans always shifts from D-OD locked, any throttle position. In fact it always shifts from 2-3 locked also. I have no switch and it never stalls coming to a stop. It is never locked in 2nd however. I dont know about busting shafts, but I dont tow heavy and I always am accelerating WOT. Havent broke a shaft yet, but I have no clue if they are stock or what I got. Bret
cowboykilla235
02-17-2013 03:02 PM
shadow4
06-19-2011 03:16 PM
samiam4
07-15-2010 01:39 PM
riffman
10-19-2005 04:12 AM
Quick Reply: replaceing factory controls with a lockup switch
