relocating the battery
Old 05-15-2007 | 04:48 PM
cyric's Avatar
I am in the process of buildind a set of twins and my question is when you guys have moved your battery to make room for the air cleaner, did you reuse the stock battery tray and modify it of did you fab up a whole new tray? I tried doing a search and came up with nothing found pics of the batteries moved but I can't see the tray to see how it was done.
Thanks in advance,
Joe
Old 05-18-2007 | 08:35 PM
cyric's Avatar
Bumpin this back to the top.
Joe
Old 05-18-2007 | 11:46 PM
Tiger Rag's Avatar
I guess it depends on what your One battery is. I think a lot of guys are running an Odyssey and I believe its footprint will sit in the factory tray with no issues. It costs about the same as two batteries however.
I wish I could give you personal experience but my BD twins don't require giving up a battery.
Old 05-19-2007 | 12:41 AM
csutton7's Avatar
I modified mine when I did it back in '01 and then used a REDTOP Battery---chris
Old 05-19-2007 | 02:26 AM
2whistlers's Avatar
I've got a buddy that only runs one battery on his '01 and has no troubles even in temps around 10 degrees. Mine on the other hand sounds like it struggles with 2 new batteries in the dead heat of summer.
bnold
07-17-2007 09:07 PM
Elkslayer
08-26-2004 01:27 PM
KATOOM
23
07-28-2004 02:17 PM
N.Johnson
06-24-2004 09:23 AM
Rattlerattle
06-30-2003 07:19 AM
Quick Reply: relocating the battery
