relocate pump and filter
Is there any reason not to relocate fuel filter (OEM) and lift pump to inside frame rail, giving you easy access to each? rather than just relocate filter, I plan to use a Wix 24309 filter head and Wix 33123 12 micron spin on water/fuel separator. put them both just ahead of tank, use 1/2 " hose from pump to filter, then on to IP with 1/2 " and do away with the banjo fittings altogether. any suggestions or comments are welcome.
jentas
33
03-07-2008 02:45 PM
