Redline Vs Tst
Redline Vs Tst
My brother-inlaw is looking for a box to turn up his 00', he wants a hot one!! Witch one of these boxes will work for him? I see the TST Stacks well with the Smarty, He also wants alittle more RPM, will the Smarty do that?
The redline box really isn't a streetable box. Especially with it set on kill. It'll trash an injection pump in 60 secs and will make mince meat out of a tranny. The TST would be a better everyday box and it still adds an adjustable 120hp. And trust me, it DEFINATELY stacks well with the smarty and with the TST/Smarty stack the truck will fuel all the way to 3500.
DTR Advertiser
I own all 3 big hp boxes as well as a smarty for stacking on the tst or redline. I make the most power with a drag comp alone. I have dynoed the same dyno, same day to be sure I could give all of them a fair shot. I have daily driven a smarty and redline and it felt great but the numbers were not there. Same way stacking a smarty on the drag comp. It felt great but was down about 50hp compared to just a drag comp. I am not bashing the smarty, it does a lot of things real good but on trucks over 500hp it usually costs power. Like I said I own all 3 and anyone looking for a redline or tst I will cut you a good deal on a slightly used one, but the drag comp I am keeping. Tim
Hey Tim- is there any way you could post the graphs of the different combos? I'd be interesting to see. Would you expect the smarty/tst or smarty/redline or outperform the drag comp on a load dyno and more accurately represent what you feel on the street?
BTW are you a Mitusa vendor now?
From what I've been told the redline actually takes control away from the truck's ecm in order to rev to 4k which I'm thinking would not make it a good stack for the smarty. FMS or even a APB should complement the smarty better. Besides, unless you've gone into the motor you don't want to be revving past redline ayways.
How high does the drag comp rev to? 3.2k?
My old three level Power Edge Pro stacked with an EZ gave 10 hp more than the Comp ... same day on Edge's dyno. The Edge boys weren't surprised at the results and had an explaination, which I've forgotten now. Kept me from moving to the Comp for three years.
The most positive benefit about the Smarty is the power increase without any boxes. Boxes are a big source of VP44 failures, according to II. Most especially fueling boxes, with the Red Line being the worst.
Thanks guys, He wants to set it up for pullin but in like a street class that allows boxes,intake and exhaust! I told him that he needs to up grade the tranny and fuel system and get a hot vp pump from II, anyone runnin one of those vp's?
Different combo's work better in different situations. There really isn't a one size fits all. This goes with fueling enhancements as well as turbos, trans mod's, etc. This forum will help a lot with determining what combo works for what your goal is. One thing to watch out for is that when someone says (for example), that they really like their HRVP, and someone else says they really like their Mach 7 injectors, and drag comp. This doesn't mean that a HRVP, Mach 7's, and a drag comp would make a good combo. It might...but it's doesn't mean that it will.
My $.02 worth...
Paul
My $.02 worth...
Paul
CumminsRedneck
10-13-2014 04:49 AM
stuckey200224
55
09-01-2007 09:43 PM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
