Redline
Redline installed, help me figure this out!
I finally got the Redline installed today & took it for a spin. I set Smarty on sw3 [timing 1, duration default as well Torque] I then set Redline on 93% & left for town. I had very little power, so I set Redline at 90%. Still low power, so I kept taking it up from 94% to 100% & felt like it was shuddering over redline. I pull over & put Smarty on sw9 [timing 4 with all others on default] Now it has plenty of bottom end, but still feels weak overall. Is there something else that I need to adjust to get it to run better?
Try setting your Smarty on SW1 and set timing to 3, everything else default. Just to let Redline handle all the fueling, Smarty just timing. Let me know what it does.
I'll try that tomorrow. I have tried sw3 with timing on 1 &4. Sw9 with timing 1 & 4, then sw9 with timing 1 & 4 + duration on 5. It still doesn't have nothing on the Adrenaline.
I turned the key forward to start the truck & the box did its diagnostics test & said "TPS voltage too high". My APPS was reset when I changed it to match my pcm voltage.
After talking to Chip yesterday, I set my APPS voltage to .6v at idle & 3.4v wot. I am now getting full fueling. I hooked the ADR to map sensor first, then Redline behind it. The truck is now revving right & fueling hard. I need to do more driving to give honest feedback, but from the testing this far....it doesn't feel stronger than Adrenaline alone. I will get some egt, boost comparisons maybe tomorrow. If I can get some seat time. I have to go help my Sister-in-law move or I'd run it today.
CumminsRedneck
10-13-2014 04:49 AM
Battering Ram
06-06-2003 08:58 AM
