Reason FP guage isn't working
Old 01-14-2006 | 04:37 PM
xp8103's Avatar
Well, I finally discovered why my fp gauge wasn't working. I took off the 18" fuel line that goes between my schrader valve and the isolater and a little white plasticky piece, all mangled up. The fuel line is from Geno's garage. The little white piece I believe is what pushes the plunger in the schrader down. i've emailed Geno's but wanted to know if someone else here had had this happen. It's clear that I likely tightened the connector too much on the schrader (live and learn) but I dont believe that there were any warnings.
Old 01-14-2006 | 06:20 PM
2500Ram's Avatar
I have the same 18" hose from Genos, all brass, no plastic.
Old 01-14-2006 | 10:06 PM
xp8103's Avatar
Interesting.....
When I look in the threaded end that connects to the schrader, there's nothing in there to open hte valve now. Not sure of the what or why of this..
Old 01-15-2006 | 02:31 AM
Vulcan's Avatar
Just remove the core and put the fitting back on.
Old 01-15-2006 | 09:31 AM
Clunk's Avatar
Eric, do you use a regular valve stem core removal tool to remove the Schrader Valve core?
Old 01-15-2006 | 06:47 PM
phox_mulder's Avatar
Yes.
Just like bicycle tire tubes.
phox
chuxtruk
13
11-03-2007 01:09 PM
A-Poc
05-05-2005 10:52 PM
greasy
03-14-2005 01:35 PM
halerazor
12-29-2004 10:00 AM
Dodgezilla
03-13-2003 07:14 AM
