Re-Oiling K&N
Re-Oiling K&N
OK i just cleaned my K&N letting it dry getting ready to Re-Oil how much oil should i use i dont want to over oil the factory oiling seemed good on mine as i checked manytimes and no oil was allowed into the turbo. Just want a good measuring stick for oiling!<br><br>-Ian
Guest
Posts: n/a
Re:Re-Oiling K&N
Usually, simply following the printed directions is a good place to start... ;D ;D
I usually carefully apply a decent spray of the oil from about 4 inches away down the outside of each outer pleat in the element, then let the filter set a couple of hours to allow the oil to spread throughout the material - then check to see if there are any obvious thin or missed areas that need touching up - it's better to apply one or more THIN applications, than one TOO HEAVY one that leaves oil dripping off the filter...
Never had the slightest problems doing it my way...
Re:Re-Oiling K&N
I just did mine too. I haven't checked to see if there is any evidence of oil in the turbo. What harm could come from getting a little oil in the turbo inlet anyway? Any thoughts?
Re:Re-Oiling K&N
I heard that a K&N air filter messes up your IAT or MAP sensor because of the oil but thats just what I heard so I think I am going to just use a regular fleetguard. What advantage is ther to oil anyway? Just my $.02
Guest
Posts: n/a
Re:Re-Oiling K&N
The "problem" with oil in the intake tract, is that it can coat the insides of the intercooler, and reduce it's efficiency - plus, the oil coating can attract and collect dust, which makes the problem even worse...<br><br>As to what's the purpose of the oil, see the above - the oil - which in the case of the K&N is NOT simply "oil", but a special oil-BASED solution that is tacky/sticky in composition, and is applied to attract and hold dirt and other contaminents as they pass by in the airstream - the makeup of the K&N, as well as the "oiling" process, allows them to hold far larger percentages of contaminents, while still functioning efficiently and passing high volumes of air...<br><br>Lots of folks don't like the requirement of occasionally handling and cleaning the K&N's, and there's always the few who experience leakage problems past the filter due to poor installation or defective filter housings - the same things happen with stock paper filters - folks are just less aware or sensitive to the problem when it's a paper filter doing it... ;D ;D
Jim Dynomite
07-15-2006 03:44 PM
Intercooler
17
06-06-2005 03:11 PM
LinearX
04-19-2004 06:28 PM
