raptor wiring harness
how long did it take to install
is the pump loud
are u using the stock filter i would like to keep all that stuff just splice into the main line going to the fuel filter
thanks guys for the info going to save a little to get the pump was thinking of the fass ddrp but reading some forums started to change my mind
is the pump loud
It took me about 1 hour to install. Everything you need comes in the kit. Just need a few wrenches and a knife to cut up the hose. Very easy installation- Mount pump (clamps to frame rail), put ends on hoses, put one hose on tank and screw other end to pump inlet, put one hose on fuel filter housing and screw other end to pump outlet, connect wiring harness to stock harness, check pressure (bought a tapped banjo bolt and used a Caterpillar High Pressure test port, a long hose, and a gauge). The pressure came preset at 15psi@idle, 10psi@full load.
The pump is no louder than the stock pump. Definately can't hear it over the engine.
This pump has a lifetime warranty and is so similar to the FASS I began to ask myself- why would I spend more money for the same pump??
you should look at a PPE fuel pump. I got a 160gph pump for half the price of a FASS. It is quiet, reliable, easy to install, and holds great psi. I have it tuned to 15psi and it drops to 12psi on a wot pass
White97GTVert
13
04-21-2011 09:51 PM
wyododge
01-13-2009 03:25 AM
84mphcdt
16
12-19-2007 12:31 PM
