Raptor fuel pump questions
I have the Vulcan big line kit with carter pump mounted on frame rail, the Carter lift pump is starting to die again and seriously thinking of installing the raptor pump. Now my question is: Can i use the wiring harness from the vulcan kit to power the raptor or do you use new wiring and bypass the pcm or ecm which ever controls the pump at start-up and is this going to do away with bumping the starter to prime the fuel system?.
the Raptor will come with everything you need to hook it up...1/2" lines, new plug n play harness....super easy install AND lifetime warranty
you wont need the vulcan kit any more the raptor comes with all the same stuff set up for each other so you wont have to hack it together.
53 ****** Is Correct, The Raptor Comes With Everything. It Took About Two Hours To Install The Raptor 150 Just Because I Had To Drop The Tank To Install The Draw Straw. My Dads Was Alot Easier Because He Went With The Raptor 100 Which Doesnt Require The Straw. Trust Me, You Will Love Which Ever One You Go With.
randallp84
14
12-10-2009 09:02 AM
03veggieram
03-17-2008 12:42 AM
84mphcdt
16
12-19-2007 12:31 PM
