Raptor fuel pump
Raptor fuel pump
I hear the Raptor fuel pump is same as AirDog but with out the filters.
Is anyone running this pump? Does it just have 2 lines(inlet and outlet)
Another question, I see the airdog has a 3rd line/return to tank. What about the return line comming back from the VP44? Do you have to have 2 return lines?
Much bigger than the factory pump. It comes with everything to install. Brackets for the frame rail, lines, and fittings. The 100 uses factory pick-up tube, 150 you need to install Draw Straw.
03veggieram
03-16-2008 11:42 PM
84mphcdt
16
12-19-2007 11:31 AM
