Which Rancho Shock?
Old 07-22-2005, 12:17 AM
JBlock's Avatar
9000 work fo me too
Originally posted by CTD NUT
I have owned many sets of Rancho 9000's over the years and have not had problems with them......the only problem I have ever had was some bad seals around the adjuster ***** that let moisture in.........I much prefer the 9000 over the RSX......FWIW, the 9000 in-cab controller set-up is junk - they are not durable and leak air. I'm with RJ, I have no problem leaning over to spin a **** to have the exact amount of dampening I desire.
I installed 9000's, and like them too, They were a big improvement over stockers at 30,000 miles and now at 60,000 no problems yet. I just installed Toyo M-55 in the 285 size, so they get worked a little harder, first impressions are they very good with the Toyo's. Tthe adjustiblity is plus, if they get loose I crank them up a notch or two. Currently set at 5 50%) on the front and 2 (20%) on the rears. Seems to tow OK for me up to 10,000 poundswithout adjusting them up.
Joe
Old 07-22-2005, 12:22 AM
JBlock's Avatar
9000 work fo me too
I installed 9000, and like too, the adjustiblity is plus, if they get loose I chrank them up a notch. 5 on the front and 2 on the rears. Seems to tow OK for me up to 10,000 pounds.
I got mine through Sams Offroad too.
Joe
roccoboost
06-21-2010 09:35 PM
jlipskoc
09-28-2005 04:38 PM
Palmetto_kid
08-01-2004 10:18 PM
Madoco
09-09-2003 01:46 PM
j
11-10-2002 10:40 AM
Quick Reply: Which Rancho Shock?
