Ran on the dyno this weekend
Torque is a function of HP and RPM. Identical HP at lower RPM=more torque. You have a 65mm turbine on your identical compressor sized turbo. The smaller exhaust wheel combined with smaller housing and smaller wastegate puck means that your turbo spools up faster so you make higher HP at lower RPM. Then, due once again to the smaller turbine of your turbo, you run out of lungs on the top end because your engine cannot exhale as much exhaust with the high drive pressure quick spooling 65mm wheel and smaller wastegate bypass puck.
I'm actually wanting to go with one of II's silver series with the 74mm turbine wheel. Still not sure what size to go with on the compressor size.
I have a video of the run too. Keep an eye on the kid holding the tube on my exhaust, kinda felt sorry for him, lol
http://www.youtube.com/watch?v=q_jsfjhzxdY
As for the kid holding the exhaust tube, it didn't look like he was enjoying himself too much there.
madhat
25
11-10-2009 08:29 AM
Bobcat698
09-30-2008 12:26 PM
MikeThomas
03-31-2008 02:46 AM
johnsjas
14
05-02-2006 10:50 PM
amartinson
14
09-19-2004 10:51 AM
