Ran on dyno over the week end
I put my truck on a dyno for the first time this week end. I made 510hp/1250ft-lbs. I am pleased but now I know what I have and need more.
Originally Posted by powerwagon440
nice. what are you mods?
Mods:
220 injectors
Bully Dog 4 plate
HTS Transmission and v/b
turbo
191 DVs
HTS Dyno Day
http://www.htstransmissions.com/DynoDays06.html
My numbers weren't quite as good as Jason's
Randy
Randy
Originally Posted by Charlie8301
HTS Dyno Day
My numbers were quite as good as Jason's
Randy
Randy
Wow
those are some numbers.. congratulations! im happy for ya.. i hope to reach that soon enough...
Rick
Hey,
Off topic but I just put a comp box on my dad's truck and haven't tapped the wire because of warrenty. Does the bd pump cover solve this problem. If the vp goes bad just switch it back to the stock ocver and send it in right?
Hey,
randy
The pump cover makes it alot harder to find the "wire tap" part of things, but the electronics in the pump will still give it away.
HTS Dyno Day
Randy
Randy
To me, that says dyno operator error or truck in need of tuning....
jmo
Originally Posted by HOHN
Randy, your peak HP and peak TQ occur only 200 rpm apart?
jmo
jmo
All Of The Runs That Day Were Automatic Trucks. All Were In 3rd Gear, Tcc Lockup And A Dead Pull, No Spikes, No Shifts. I Must Say Myself That The Dyno Did Seem Tight. The Dyno Operator/owner Was Used To Drag Gas Cars. I Have Thought About The Same Thing. It Was However, An Eddie Current, Mustang Dyno, If That Is How You Spell That. A Fun Day, And A Lot Of Thunder On The Rollers Guys.
It Was Hard To Do An Auto Truck Without It Wanting To Downshift.
Dhawk Htstransmissions.com
jmo
jmo
Randy
Why is that? Does the cover cut into something?
Randy
The pump cover actually runs a small allen screw into the circuit board, if you know what to look for you can see it. But I think if they test the pump after you remove the wire tap there is still some tattletales stored in the pumps electroncs, the dealer might not find it, but cummins/DC probably will
Randy
Randy
madhat
07-24-2010 08:19 PM
ShaneCTD600
14
04-15-2007 11:42 PM
