Ran a 12.48 @ 109mph on Saturday
Old 06-25-2003, 11:25 AM
Idaho CTD's Avatar
Some already know about my 12.48 and 12.49 runs but Stephan Kondolay informed me about a picture of my truck so I thought I'd post it. I thought it was pretty cool to get mentioned along with a bunch of 8sec. cars. Also on the page is a picture of Bill Kondolay in the Wolf Pack Camero.
http://www.horsepowerheaven.com/feat...3mrpjun21a.htm
Old 06-25-2003, 12:38 PM
SjLingenfelter's Avatar
Re:Ran a 12.48 @ 109mph on Saturday
Congrats. You truck looks cool on that launch!<br><br>
Old 06-25-2003, 12:42 PM
redramnc's Avatar
Way cool !!!<br><br>Just try to get any of those other guys shown past a HP traffic checkpoint :<br><br>Or commute to work in one........with A/C
Old 06-25-2003, 03:54 PM
OlBlue's Avatar
AWESOME!!
I miss all your smoke!!! ;D
What about leaving the weight of the tailgate at the pit????
Old 06-25-2003, 04:58 PM
pro puller's Avatar
kurt.
Old 06-25-2003, 06:12 PM
quantrill88's Avatar
thats incredible <br><br>i want ur truck ;D
Old 06-25-2003, 06:49 PM
DPG
DPG's Avatar
Very impressive, IdahoCTD!! I've haven't been to a diesel drag race yet, going to Martin (Michigan) Dragway on July 19 for a DHRA Division 3 event. Do you guys run in 4WD off the line, for traction?<br><br>DeWain
Old 06-25-2003, 07:28 PM
Idaho CTD's Avatar
Rob/Ol Blue,<br><br>I was going to strip a few things off the truck for the races on Sunday but it got rained out so that never happened. The spare tire, tailgate, sub box, and rear seat were going to be my lightening effort to try and reach 11 seconds ;D<br><br>DeWain,<br><br>Yes I run in 4wd the whole length of track.
Old 06-25-2003, 09:54 PM
DavidTD's Avatar
Very Awesome sir!!! <br><br>What does the truck weigh? I'm thinking about 7250.<br><br>You'll need to shave about 800 pounds to break the 11's at the same power level according to my calculations.<br><br>Awesome picture too. What was the 60ft and 1/8th. Ready for that Roll Bar... ;D
Old 06-25-2003, 10:50 PM
StakeMan's Avatar
Greats times Idaho.<br><br>I hope to see you at Bandimere for Truck Fest. Hope to line up next to ya.
Old 06-25-2003, 11:52 PM
KatDiesel's Avatar
[quote author=Idaho CTD link=board=7;threadid=16338;start=0#153420 date=1056587315]<br>Yes I run in 4wd the whole length of track.<br>[/quote]<br><br>Try shifting out of 4wd when your in 2nd or 3rd.......you'll go faster, if you have traction.
Old 06-26-2003, 02:50 AM
Idaho CTD's Avatar
[quote author=DavidTD link=board=7;threadid=16338;start=0#153473 date=1056596048]
Very Awesome sir!!!
[/quote]
I dont know exactly but I think it is closer to 7100 right now. I know I can easily lose 3-400lbs and I know it will run faster than I did in Canada. I was only leaving with around 18psi of boost. It was a whole new tranny so I was trying to get a feel for it. I also installed a lockup switch on Sunday in hopes to run again later that day but the rain prevented that. My new output shaft should hold 30+psi launches. I dont know if the intermediate will though. I really just need more time behind the wheel to work on my launches. I have only made a total of 11 passes on a drag strip ever so I'm still learning. I probably could also use some traction bars.
60' was 1.877, 330' was 5.221, 1/8th was 7.99 @ 88mph
Hopefully the lockup switch will help my dyno numbers as well. Up til now I have been running up to 70mph (1900rpms) and flogging it. My last dyno run I only made 62psi of boost but I made 79psi on the track (622hp)
Kat,
I dont know if kicking it out of 4wd will help on my truck without the front axle disconnect. It's a late '02 model. I will give it a go to see if it helps though.
Nathan
P.S. No rolls bars for this truck. Once I get kicked out I'll work on a real race truck. Something pushing low 9's to 8's ;D
Old 06-26-2003, 02:57 AM
KatDiesel's Avatar
[quote author=Idaho CTD link=board=7;threadid=16338;start=0#153538 date=1056613809]Kat,<br><br>I dont know if kicking it out of 4wd will help on my truck without the front axle disconnect. It's a late '02 model. I will give it a go to see if it helps though.[/quote]<br><br>Doh forgot bout that sorry. Try it anyhow just to see <br><br>
Old 06-26-2003, 12:10 PM
OlBlue's Avatar
[quote Once I get kicked out I'll work on a real race truck. Something pushing low 9's to 8's ;D
<br><br> WooHoo! <br><br>I was just giving you a hard time about the tailgate! Actually, I think it is WAY COOL!, streetable rig - waking everyone at the track up like that!!!!<br><br>Get practiced up and then DON'T come to Diesel Thunder!! ;D<br>If you do get to Spokane, It'll be great to see ya again!
Old 06-26-2003, 09:17 PM
Jim Fulmer's Avatar
Good job on the passes Nathan, I was looking at old time slips of mine and your within 1 to 2 MPH of me and I'm at 6400 lbs so your power is right up there, now your ET's and can't match nor can I do a dang 18 psi launch...10-12 max! The lock switch in high gear will net you some too but more with me as I have a loose converter.....keep us posted.<br><br>Jim
Quick Reply: Ran a 12.48 @ 109mph on Saturday
