Rain and stacks...
Old 11-16-2004, 08:54 PM
silverbullet02's Avatar
Rain and stacks...
Gonna be putting 5" slash cut stacks on here shortly...anybody have any problems with rain? I mean, it'd prolly take a bit of rain to do anything...I can just imagine firing this thing up and having 2 water fountains...
Old 11-16-2004, 09:24 PM
BigBlue's Avatar
You'll get a bunch of black splatter when you fire them up. Drill a 1/16"-1/8" hole at the lowest point of the system so the water has some way to drain out.
Old 11-16-2004, 10:45 PM
yzfr6's Avatar
could that cause exhuast to leak into the cab?
Old 11-16-2004, 10:49 PM
Forrest Nearing's Avatar
not unless you've got holes in the cab...
I didn't drill any holes in my pipes, but I've got a couple PINHOLE sized holes in a couple of the welds that I didn't catch, and I've only had a couple spots here and there after a rain... my old stack setup put soot EVERYWHERE when water got in the stacks!!!
I have less exhaust smell in the cab now than I did with the exhaust exiting in the back... at stop lights, I used to have to put the AC/heat on recirculate. now with the stacks, I can leave it on fresh. all the air is pulled through the cowl, so a 1/16" hole under your bed isn't going to cause exhaust vapors to enter the cab.
Forrest
Old 11-17-2004, 12:37 AM
Jambbii's Avatar
I left my truck sitting for a day while the turbo was out and it was raining. I dont have any holes in the exhaust either and when I fired her up I had black splatter everywhere, on the cab on the bed etc. It comes off real easy its just a pain sometimes.
Old 11-17-2004, 11:05 AM
dodgeman01's Avatar
I have turnouts and even after a down pour I have never had splatter and soot stains. Plus I think Turnouts look better but thats my opinion. Hail turnouts
DM01
Old 11-17-2004, 11:24 AM
BigBlue's Avatar
No one cares about your opinion Aaron. MITERS RULE!!!
Old 11-17-2004, 11:33 AM
DeereDiesel's Avatar
I had turnouts on my truck and I had bed spatter all the time. I put straight onnes on and dont have near the problem for some reason
white truck + stacks = wash it alot
carty
Old 11-17-2004, 11:46 AM
agreed... I had turnouts... tons of soot shower everywhere... so I said, if I'm gonna have soot shower, I might as well have miter cuts (I think they look better)
I don't have near the problem I did w/ the turnouts!
my truck is white BTW!
Forrest
Old 11-17-2004, 12:17 PM
dodgeman01's Avatar
Forrest
I have never hadd any soot. My stacks are also turned straight out so maybe that helps me but even when I had the slanted last year I did not have a soot problem.
DM01
Old 11-17-2004, 03:50 PM
I don't remember whose idea this is, but I read a post from somebody who ran the 4" pipe up inside the 5" stacks for a foot or so. The adapters were drilled to allow the water that collected to drain outside the pipes. It rarely rains straight down, most of the water hits the stack walls and drains so nothing gets into the exhaust to come out as black splatter. The set I'm building will incorporate this idea.
Old 11-17-2004, 04:08 PM
that's for a stack setup that uses a box crossover... the "Rob Thomas" setup
Forrest
Old 11-17-2004, 04:10 PM
If you're running 4" in the bed and adapting to 5" for the stacks there's no reason it wouldn't work just the same.
Old 11-17-2004, 04:18 PM
I suppose you're right. I'm planning on running twins in the future, so I went w/ 5"
Forrest
Old 11-17-2004, 09:14 PM
mr T's Avatar
i got miters i get all kinds of rain and all u get ir vapour for about 30 sec...its no bid deal now snow!!! that concerns me this winter yep im on friggin Toronto...
but i dotn have any funny holes in the system anywhere an dive never had soot problems
Quick Reply: Rain and stacks...
