Rack stop fuel plate
Old 10-28-2003 | 01:04 PM
southernsmoker's Avatar
Is there a plate that serves as just a rack stop to prevent the rack from digging into the governor? If so, where can I get one? Does anyone have a picture of one? I am in need of a plate bigger than a #4.
Old 10-28-2003 | 01:49 PM
Got Smoke?'s Avatar
Re:Rack stop fuel plate
[quote author=southernsmoker link=board=16;threadid=21630;start=0#msg202627 date=1067367870]
[/quote]
Taking a plate and grinding it flat to equal a "Zero" plate allows for maimum rack travel, without the fear of over extending the rack.
That's what I plan on doing as soon as I get my HX40 rebuilt and on. ;D
Old 10-28-2003 | 02:03 PM
How far do you grind though?
Old 10-28-2003 | 05:21 PM
bulthisl's Avatar
Flat.
Or straight with the furtherest bit of travel thats already there.
Are you planning on grinding on that #4 plate?
If so would you want to sell it and grind your stock plate?
: Eddie : 8)
Old 10-28-2003 | 06:49 PM
dodgeman01's Avatar
well I heard that if you take a #10 plate and measure the top of the curve with the plate slid all the way forward it is at the #0 plate spot. and on my #10 that is 1 1/4 from the back.
DM01
Old 10-28-2003 | 06:57 PM
98rammer's Avatar
i ground my stock plate to a #0 (though i'm not using it at the moment). make sure that the rackstop isn't going underneath the #0 in which it will likely do when the plate is in the middle. then you have to do the lever adjustment, but make sure you tighten the arm adjustment locknut screw tight.
Tom
Old 10-28-2003 | 07:34 PM
Mostwanted's Avatar
I took my rackstop out, er it sortof broke when I was trying to put the top back on. So, I just threw it out!
Old 10-28-2003 | 08:38 PM
Jim Fulmer's Avatar
Play with your plate but remember 18mm of rack travel is better than 21 (max) I have proved this at the track and on the dyno....more isn't always better....guy thing!
Jim
Old 10-29-2003 | 11:55 AM
J.R. Adkins's Avatar
[quote author=Jim Fulmer link=board=7;threadid=21630;start=0#msg202840 date=1067395090]
Jim
[/quote]
Jim I do agree to this statement to a point. Most street driven setups cant handle more than 18mm.
J.R.
Old 10-29-2003 | 12:02 PM
dodgeman01's Avatar
what hapens after 18 that makes the truck lose HP?
DM01
Old 10-29-2003 | 12:05 PM
[quote author=dodgeman01 link=board=7;threadid=21630;start=0#msg203077 date=1067450558]
DM01
[/quote]
Takes air to burn fuel. What happens when you run out of good air???!!!!
Old 10-29-2003 | 12:09 PM
dodgeman01's Avatar
[quote author=J.R. Adkins link=board=7;threadid=21630;start=0#msg203078 date=1067450729]
DM01
[/quote]
[/quote]
what a bout if you go to a bigger turbo can you slide the plate a little more?
Old 10-29-2003 | 12:36 PM
BigBlue's Avatar
Very simple. MORE BOOST!!!!!!
Old 10-29-2003 | 12:40 PM
98rammer's Avatar
no, it's not as simle as more boost. it's about air temp/*density* of oxygen. more boost creates more heat which means that the intake air isn't as dense and therefor there's less oxygen per part.
with all of that rack travel, you're buring the fuel late anyways which may not (and usually doesn't) equate to more horsepower.
Tom
Old 10-29-2003 | 12:41 PM
BigBlue's Avatar
[quote author=98rammer link=board=7;threadid=21630;start=0#msg203104 date=1067452809]
Tom
[/quote]
I was being sarcastic. Jeez.
Quick Reply: Rack stop fuel plate
